Question about Sewing Machines
Screen looks shattered but touch still works
Screen started going dark from middle now the whole screen is dark but touch still works
  • Sewing Machines Master
  • 1,388 Answers
Contact Us at Bargain Box with a few more detail
Posted on Apr 22, 2014
Bernina 180E Touch Screen Dark, machine light won't come on.
I don't know the circuit of this sewing machine but it gives me the impression the light and the board are in series with a fuse. If this is true the light will burn out and cause the screen to go black as well. If the fuse would go out the same thing would be true. Anyway, change the light first. If this doesn't work you will need to replace the fuse. If there are still problems it will need the mother board to be replaced. Tell me how this worked out.
Oct 24, 2014 | Bernina Artista 180
How do I back stitch
You push on the backstitch button. It's the button that looks like an upside down U. If all it does is take a few tiny stitches back then stops...you need to look at the screen...to the upper right you will see the upside down U and a scissors. make sure both of these are not selected. If one or both have a dark background...touch them and the background turns white/clear. Once they are unselected...you can backstitch at the same speed as going forward.
Jun 19, 2014 | Brother SE-270D Computerized Sewing...
Brother pr-600 screen not responding
See if you can discover how to reset the machine. Typically it is a combination of buttons pressed either simultaneously or in order as the machine is starting.
Dec 10, 2012 | Sewing Machines
I have a designer 1 and when i select the option block that I want - i actually have to touch below it a whole block for it to register what I wanted!! Help!! We moved states away from where I bought it.
Do you mean that you can't select a stitch except by touching below that stitch instead of on it? If yes, then you need to re-calibrate your screen. It's easy! You should use your stylus for this, but if you have lost it use the blunt end of a machine needle instead.
Go into your SET menu, hit More twice - or until you see "Color Touch Screen Adjust" (it might depend on what version machine software you have loaded just which screen it is on). Click on this. (Keep touching below and around the button until you get it to respond.) Touch in the CENTER of cross 1 (upper left corner of screen). When the cross changes from black to green, the point is set. Do the same with cross 2 (lower right). Done!
Just be sure to touch ONLY THE CROSSES on that screen, except for OK when you are done.
Nov 29, 2009 | Husqvarna Designer I
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Nov 16, 2009 | Husqvarna Designer I
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
Touch Screen for Janome MC 8000 required
We have the Janome MC8000 touch screen avaliable please contact us from our website www.sewingmachine.com.au
Mar 11, 2009 | Janome L-344 Mechanical Sewing Machine
I have a viking sewing machine designer 1. The touch screen is dark and there is nothing on the screen. What needs to be done?
You can try running the latest update on the machine. I have heard of a person turning their machine off in the middle of an update and this is what it did.
You don't have to be able to see the screen to install the update, and it's free to try.
Next, if this doesn't work, go to an authorized service center.
Aug 13, 2008 | Husqvarna Designer I
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
