Question about Panasonic Lands Phones
How to turn up volume on cordless phone
Can't hear caller on other end of phone how to turn up volume
  • kakima Mar 31, 2014
    What model Panasonic cordless phone?
    Sergeant:
  • 360 Answers
On many Panasonic cordless phones the large center button (either black or silver) has 4 small arrows. By depressing either the upper or lower portion of the button should control the volume.
Posted on May 09, 2014
SOURCE: I can hear caller but they can't hear me
I had the same problem with two of these handsets. I am not certain of the cause, but based on the fix, I believe water got into the microphone holes and perhaps mixed with a water soluble glue that stuck the felt cover to the microphone. I fixed the problem by removing the battery, opening up the phone (slide the battery cover off and removed the 4 screws) and snapped open the plastic encasement. Then I remove the two screws toward the top (toward antenna) of the circuit board. This gave me access to the microphone which is on the underside of the circuit board (very bottom of the phone, below and on the opposite side of the plastic jumper for the battery) which had a thin black felt cover covered in a sticky residue that was covering the microphone diaphragm. I removed the felt and then used a cotton swab with rubbing alcohol to remove the residue from the diaphgragm. I used compressed dry air to remove any dust from the diaphgram. With the 2 screws, I secured the circuit board back in, snapped the plastic case back together. Then I finished off with putting 4 screws in the case and putting the battery in. Now other parties can hear me just like they used to when the phone was working.
Posted on Jan 19, 2007
  • 193 Answers
SOURCE: Callers can't hear me but I can hear them
change the channels on the phone and reboot it
Posted on Oct 09, 2007
SOURCE: Philips CD240 cordless phone
need manual for philips cordless phone CD 240
thank you
degs
Posted on Aug 29, 2008
SOURCE: caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Posted on Dec 22, 2008
SOURCE: I can hear caller on handset but they cannot hear me?
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
Posted on Jul 16, 2009
Cordless handset. Why can't callers hear me?
normally, it is because the Mute button is pressed, but you say they can hear you, but not very loud? Make sure the bottom of the phone is close to your mouth. Look in the mirror. Also find the volume setting on the phone, and turn it up full. This is generally accessed via and options button, scroll through until you find 'Volume' and then press the up arrow.
Nov 19, 2015 | Lands Phones
How to turn volume up for callers sound
You're going to do this during a call.
During the call,
  • You will press the "cid (up arrow)" or "pbk (down arrow)" buttons to display the current volume.
  • Then pressing either or those buttons again would bring the volume up or down of the caller/earpiece.
If you don't hear any difference, then the problem is most likely on the caller's end.
**I assume you have a phone that looks like the one displayed in image
Aug 19, 2015 | Philips CD445 Cordless Phone
How to turn volume up so you can hear caller
in the center of the phone is a small square window with small arrow pointing up and one pointing down. volume inceases evey time you click on it and decreases every time you click on bottom arrow
Sep 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
Have Uniden EX14560 and do not know how to turn ringer back on..can you help me?
Do you mean the Uniden EXI4560 2.4 GHz phone? With the handset in standby, press the volume up button (above End and just below the LCD screen). Then you will be able to toggle between the 5 available ring tones and volume levels. (I'm assuming the unit is set to Ringer Off which is another choice in the list.) Press End to confirm and save your ring volume setting.
Most Uniden manuals are available from Uniden on the product page or the support page. The product page is http://www.uniden.com/cordless-phones/24-ghz-extended-range-cordless-technology/invt/exi4560g/ . Then go to the Manuals tab. The direct link to the EXI4560 manual is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EXI4560om.pdf .
All of the Uniden manuals are here: http://www.uniden.com/scat/cordlessphones_mnl . Use the drop down menu to select the type of phone and then find it in the list by numerical and alphabetical order. The EXI4560 is on page 4 under cordless phones.
I hope this helps.
Aug 25, 2011 | Panasonic UnidenEXI3226 : Two-Line 2.4GHz...
Can't hear caller but they can hear us.
press "MUTE" button. I suspect someone inadvertently pressed it causing it to shut off volume to caller.
Mar 07, 2011 | Uniden Cordless Phone
Can barely hear caller
Turn the volume control all the way to maximum on your cordless phone.
Dec 22, 2009 | Uniden Cordless Phone
My philips DECT 215 trio phone is really quiet and i need to increase the volume of the caller
To hear the volume of caller whom u called or they called ... call 2 any number and press up arrow in your device......the volume will be increased....COOL....
Sep 16, 2009 | Philips DECT 2151 Cordless Phone
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Vtech cordless phone appears to be mute
does anyone out there have a solution for peggy's problem? I have the same problem------Bob
Jan 08, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Lands Phones Logo
88 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
