Question about Yamaha Audio Players & Recorders
Yht 299 My brand new yht 299 keeps "tripping out". if i turn down the volume output it seems to stay on. After it trips out i just switch back on and it carries on. Lg blu ray dvd and panasonic viera led TV all connected.
  • 66 Answers
Sounds like your speakers might not match your receiver. check the back of your speakers for the ohms eg 4 , 6 ,8 impedance.
you have to match the specs of the receiver otherwise it cuts out.
Posted on Apr 21, 2014
  • 16 Answers
SOURCE: sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
If you need further help, reach me via phone at https://www.6ya.com/expert/abdouramane_7b3aaa187339b631
Posted on May 09, 2008
  • 11 Answers
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Posted on Sep 19, 2009
SOURCE: blu ray connect to my sc-pt660
Why not leave the audio into the TV via HDMI from the Bluray and then optical audio out from TV to the home theater audio system? Same as the hook up for the cable box. The SC-
PT660 only has one optical audio connector so your solution may not be feasible assuming he's also got a cable box connected to the TV.
Posted on Dec 30, 2009
  • 5 Answers
SOURCE: why won't the samsung blu ray players play all blu
Software on blu-ray players need to be updated occasionally. You may need to visit Samsung's website for instructions on updating the software on your player. This may be as simple as downloading a file or requesting an update disc.
Posted on Feb 13, 2010
  • 177 Answers
SOURCE: How do i connect Panasonic sc PT480 home theater
Ok, so first, you need to get the pictures to the TV. So, you should have an HDMI lead from the Bluray to the TV. You should have either an HDMI or SCART lead from the Virgin Box to the TV. If you are going to play and DVD's from the Home Theater system, this too needs a scart to the TV, but if you are planning to use the bluray for all playing back, then this is not needed. Next, you want to get the sound from all your equipment to the home theater system. This where it can get confusing, as there are different types of leads that do the same thing. If your TV has an 'Optical Out', and the Theater system has an 'Optical In' then you can connect the two with a Fibre-optic cable, and that means that anything then that you have on the screen, can have the sound through your surround sound. Digital Coaxial In's/outs do the same thing, as do Phono In's/Outs, but phono cables will not carry 5.1 digital. I hope this helps!
Posted on Jul 17, 2010
Keeps tripping power at 13minutes remaining, just before the spin cycle
Hello. It sounds like the motor has gone bad--possibly a shorted part of the motor, or a jammed drain pump. It also could be the transmission binding at the point of going into spin mode. You didn't provide a brand/model number so my help is limited. The clue here is the clicking before the power trip.
Aug 19, 2015 | Washing Machines
Jvc rx 5052 overload when volumes open
Could be....
  1. There's a short in your speaker wiring somewhere
  2. or a blown speaker
  3. or you are recycling the speakers from an old all-in-one system and they're too low Ohms
Check your speakers first. If they are less than 8 Ohms, or there's no label on them which gives the Impedance (in Ohms) then I'll lay money that they aren't suitable for the amp. Stop using them and get some proper 8 Ohm speakers.
Wiring shorts might be only a single strand of copper wire. But it's enough that at higher volumes it conducts enough current between the speaker terminals to trip the amp's protection mode.
Fix the problem. Go through your wiring. Check using a torch. If all looks good then it's a blown speaker.
Remove the speaker wires from the amp. Switch the amp on and turn the volume up full. The amp should stay on. Turn the volume down and switch off.
Now connect ONE speaker only. Try the amp on and volume up again. If it trips out then that's the faulty speaker. Repeat by adding one more speaker each time. When the amp trips, the last speaker added is the culpret.
Sep 08, 2014 | Audio Players & Recorders
Carver manual
Could be....
If you've done all the simple stuff, then what's left is a problem with one of the output transistors. It needs the output transistor(s) replaced inside the unit. These directly drive the loudspeaker outputs on the receiver itself, and one or more of them being shorted (closed circuit), will trigger the error on the display of the receiver, and it will not go off until the problem is repaired. They are not user-replaceable as they are PCB mounted, and thermally coupled to a heatsink. In this case, the unit is in need of service.
Sep 07, 2014 | Audio Players & Recorders
Warning lightsawd and abs
  • Turn the ignition switch to the On position and ensure that the display screen is in the Trip A mode.
  • Turn the ignition switch to the Off position.
  • While pressing the TRIP switch button, turn ignition switch On. Hold the TRIP button down through the entire reset procedure.
  • The odometer indicates 000000 and then returns back to Trip A.
Nov 09, 2013 | 2009 Toyota Venza
Brand new dryer keeps shutting off. not tripping my breakers I don';t understand
There is a thermal cutoff switch in all hairdryers. If you by accident block the air intake or the filter is dirty, then the heat from the nichrome wire is not sufficiently cooled to keep the thermal switch from tripping. After the dryer cools down then the thermal switch resets and allows operation. Be sure the air flow into the dryer is not obstructed
Mar 25, 2011 | Rusk W8less 2000 watt dryer
My receiver donot stays on for more than 3 sec.
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 15, 2010 | Yamaha HTR-5930 Receiver
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Dec 05, 2008 | Cooktops
Tripping BreakerS
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Sep 13, 2008 | Dehumidifiers
80 watt impedance matching volume control
check your spekaer cabling first for any loose connection. if everything as usual then something is wrong with either your speaker system or the power output stage of your amp. you may call it a "circuit breaker" but it actually overload protection of the power amp so as not to damage speakers or amplifiers. have your speakers checked for burn coils. you can also try to remove or turn off speaker switch, turn on the power, level up the volume and see it the system still stays on and does not trip (as you called circuit breaker) if the unit remains on, then it must be your speakers. though it could also be a leakage in the power transistors of your output stage, it something a technical person have to do to check anyway.
redrivera
Mar 25, 2008 | Audio Players & Recorders
74 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
