Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
P32 4L80E workhorse running rough and stopping - loss of power
Diesel motor L6.5
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
Check the nozzles
Posted on May 11, 2014
What would be the most likely cause of intermittent loss of power and turbo boost and rough idling on a volvo f16 diesel engine
faulty injectors or faulty injector control
loss of power is fuel problems ( pump or injectors )
loss of turbo boost is lack of extra fire from the combustion --back to injector or control and bad idling is injectors squirting/ not squirting and not atomizing properly
Oct 24, 2017 | Volvo Cars & Trucks
Just had headgasket replaced on 98 318ti m44 head was milled was put back together and it starts and runs but it sounds like a diesel at idle and is low on power would the timing be off causing the noise...
It's hard to diagnose from here, timing might make it run rough and loss of power, but a diesel sound at idle, that don't sound like the timing! If I was to guess, and it is just a guess mined You, I would say the head work didn't turn out as planed!
Jul 14, 2017 | Cars & Trucks
Nissan navara 2002 twin cab diesel zd30 malfunction light comes on randomly
NISSAN NAVARA questions and answers
www.roadtestreports.co.uk/vans/nissan/navara/qanda/
Results 1 - 40 of 322 - Ask and answer questions on a variety of NISSAN NAVARAmodels. Help and advice ... Have a Navarra Rally Raid 2004 double cab pick up. ... Navara V6 2011 - loss of power & engine management light on. .... ZD30 I have changed the diesel filters after noticing that it's jerking when I'm on full throttle.
Nissan Patrol GR Y61 ZD30 starting problem - YouTube
? 1:23
https://www.youtube.com/watch?v=JxHKfYDCgFQ
Jan 16, 2013 - Uploaded by sspyropoul
After replacing the diesel filter seals and water trap i had no problem .But you ... They still glow for like 15 ...Missing: twin ‎cab ‎randomly
Nissan D22 Navara receives YD25 2.5-litre diesel
www.themotorreport.com.au/.../nissan-re-power-their-d22-navara-range
Jan 31, 2008 - Nissan's popular Navara D22 workhorse range has been ... On top of the 4x4 DX single cab's equipment, the dual cab ST-R adds .... the yd25 engine have a overheating problem, so how comes nissan is ... I believe it is a ZD30 engine. .... with no problems except a cracked injector line (pretty random fault).
Jan 13, 2016 | Nissan Cars & Trucks
Ive 2006 ram3500 diesel 5.9 2 wheel drive. runs great up until yesterday driving on freeway at 75-80 mph when i experience loss off power, no throttle response. What could be the issues?
it is possible that you may have had a sensor malfunction in one of your main systems. These sensors are there to put your engine into "limp in mode" so as not to cause more damage to the engine but yet allow it to be taken safely off the road and/or to your mechanic.
Jan 04, 2015 | 2006 Dodge Ram 3500 Truck
Loss of power, rough running then stops
Blocked idle jet, worn HT lead, knackered spark plug, coil needs replacing
Apr 01, 2014 | 2001 Triumph Trophy 1200
Loss of power to renault megane diesel 1.9 dti
biggest cause of loss of power on this model is the accelerator pedal module ,what happens is the car runs ok then just loses power stop and turn it off then restart and it runs ok again for a while ,time between slow downs can vary depending driving conditions.
Nov 04, 2013 | 2004 Renault 181
I have a 2006 F250, 6.0 diesel (power stroke) it was running fine and then suddenly started running real rough (similar to the way a gasoline engine runs when it's not firing on all cylinders.) also there...
This is very complex system. Best to have it checked by qualified diesel mechanic who has the proper equipment to check out all the systems, that could be related to the problem you are having. Just to start throwing parts at it can become very expensive very fast
Feb 13, 2010 | 2006 Ford F-250 Super Duty
1990 Lumina running roung, power loss rough idle
On the chevy v6 engines it real comon to have intake leaks.I would try spraing carb cleaner around the intake while the car is running and see if it changes the way it runs.If it does that is your problem.If the intake has a leak it will **** extra air in and cause a missfire.
Mar 03, 2009 | 1990 Chevrolet Lumina APV
2008 F250 Diesel
It sounds like a problem with your computer or injection system. the computer controls the amount of fuel put in the cylinders when you step on the gas. But it sounds like your truck's computer is having problems controlling this and when you accelerate hard or are towing and step on the gas, the computer just pumps diesel into the cylinders which causes the rough running(i assume misfiring and what not) and the loss of power. But when your not towing or accelerating hard, you are better controlling the amount of fuel going into the cylinders so there arent any problems. Go back to the dealer and tell them there is a problem with the injection system and it adds too much fuel when you try to get a lot of power out of it.
Oct 20, 2008 | 2008 Ford F 250 Super Duty 4WD
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
