Question about Frigidaire Ovens
Door won't. open on frigidare convection oven #240462603 can you help?
The door on the convection side of the oven appears to be locked and we can't open it-can you advise?
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Karen, this you for your question!
I understand your Frigidaire oven (240462603) will not unlock. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
In the meantime, I suggest pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. It is necessary to wait roughly ten minutes and then turn your range on.
I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck - Z
Posted on Apr 03, 2014
textonor
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
SOURCE: frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
Posted on Feb 01, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
F8 code on my frigidare double oven after cleaning with self cleaning oven ....know this is in the lock but need to know how to fix it myself left it unpluged overnight plugged back in and its still f8...
Hi
Yes F8 is oven door lock error warning.
You need to physically check the door switches and lock relay, these will be inside the oven casing.
It is probably not the easiest of diy jobs as everything is concealed.
Dec 16, 2010 | Ovens
How do you unlock the door to a convection oven?
Here is what you do when the convection oven door locks automatically. Where the stop/clear button is, you will see a lock symbol that has a number 3 on it. hold the stop/clear button down for 5 seconds and it will unlock you convection oven.
Nov 18, 2009 | Kenmore Ovens
Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Sep 17, 2009 | Ovens
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Help
The lock motor may have failed. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. If it is a built-in over, sometimes bending a coat hanger into a hook and sliding from the right side into the lock you can unlock the door.
Jun 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
69 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
