Question about Generic Pisen Multi Purpose USB Hub, White
Pisen USB Hub burned out and wont work
I just need to know how to open it.
  • 42 Answers
Look for a seam around the case, scrape the plastic until you can pry it apart. This usually results in destroying the case and quite messy and sometime even dangerous (sharp knife, unprotected hands, slippery surfaces). From my experience liking to take things apart, and being a major Band aid user, its not worth it.
If it s done for, you might as well use a large screwdriver and force it apart from where the wires go into the case. It cant be repaired, get a new one.
Posted on Apr 14, 2014
  • 2 more comments
  • Cui Leo
    Cui Leo Apr 14, 2014
    thanks
  • Cui Leo
    is there any way i can take advantage of the burned out hub?
  • Ferenc Tar
    Ferenc Tar Apr 15, 2014
    Not really, even cutting the wires off to reuse the connectors isnt worth it, You can find all kind of wires at a pawn shop or Salvatio Army, or used stuff store.
  • Ferenc Tar
    Chuck it, one less useless stuff to cluter a drawer.
Can I hook up a 4 port usb hub backwards?
well if you plug the usb cord that powers it into some thing else that has a usb port that is running electricty through it such as a pc you should be able to plug in any thing that needs charging with a usb cord that will go into the 4 ports . so i guess it should work i know it wont mess anything up so go ahead and try it. also if you got a usb wall charger that can hold a usb cord you can plug the 4 port usb hub into that and it will work like a charger for things with usb chargers.
Dec 17, 2012 | Video Game Consoles & Games
Usb device not recognized, works only when plugged on hub
All PCs provides power supply via USB port. The power is controlled by electronic circuit. Sometimes when overloaded the circuit burns out (the last controlling transistor, actually). This does not prevent the data communication, because it is separated circuit. But if the device is not powered it cannot communicate. When you plug the USB device to powered USB hub, then all go right.
Are you able to use the USB ports with other USB-powered devices like USB sticks, mouses, cameras? If not, the mentioned circuit is burned out. If they work OK, then your internal USB hub provides less power current than needed. In both cases there is nothing to do. The circuit resides on the mainboard of the laptop and replacement is expencive. Use it with that external USB hub you have.
Apr 08, 2012 | ASUS G73JH-RBBX05 Refurbished Notebook PC...
I PLUGGED MY MP3 PLAYER INTO MY LAPTOP USB PORT AND IT USED TO WORK NOW IT SAID THE USB DEVICE HAS EXCEEDED ITS POWER LIMITS OF ITS HUB PORT AND WONT WORK NOW
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Sep 05, 2011 | Computers & Internet
My laptop is simply not recognizing my futaba interlink controller via usb hub. i know the hub works because i plug something else in and it works fine...I'm thinking just bad controller maybe?
Well i'm having the same problem.
My mouse & keyboard work trough the hub, however when i plug an USB-stick in, it wont recognize it.
I've i put my USB-stick in another USB-port, it works.
So try putting your usb, in another USB-port, thats not from your hub.
Jun 19, 2011 | Computers & Internet
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
My logitech mouse wont move
You need to install the driver for your logitech mouse to work.
If your mouse is not recognized then follow the following steps,
To work around this issue, try one of the solutions below:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If that doesn't work, here is another option you can try:
Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps:
  • Click Start, and then click Run.
  • Type devmgmt.msc in the Open box, and then click OK.
  • Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
  • Right-click the USB Root Hub and then click Properties.
  • Click the Power Management tab.
  • Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
Jun 03, 2009 | Logitech Marble Mouse Trackball
I plug in just about anything USB and the problems start
if u using any external usb hub than u must ignore the hub and plug ur usb device directly on usb . if u arent using external usb hub than u must install compatible chipset driver for ur system or re install usb drivers too.enjoy and good luck
Mar 26, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
I purchased a 4 port usb 2.0 hub can't seem to work
Have you install the driver first before connecting it? Check out the Device manager entries if showing any yellow mark?
Goto start --> Run --> type in there --> devmgmt.msc this will open up the Device manager.
Check it and let me know. Have a nice day
Mar 17, 2009 | Cable Showcase 4-Port Mini USB 2.0 Hub, AC...
Usb
If you see something wrong with the device everytime you plug in something to the USB hub doesn't necessarily mean that the hub is defective but it may actually mean that the device may not be receiving enough power to make it work. As we all know USB a device that may or may not have its own power but at least we know its working when by check the light indicator on the device or checking in device manager and that is an indication that it may or may not work with a hub and may need to be directly connected. If device you hook up is working with direct connection try isolating it by hooking it up from one port on the hub to the other this may actually help you out determining if there is defective port on the hub otherwise you got a lemon any may to return the product as well consult with them which product have they tested that actually worked with it.
Jun 28, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Generic Pisen Multi Purpose USB Hub, White Logo
108 people viewed this question
Top Generic Computers & Internet Experts
D. E. Hev
Steve
Are you a Generic Computer and Internet Expert? Answer questions, earn points and help others
