Question about Acer TravelMate C110 Tablet PC
I have a acer travelmate 2420 and it just switches off for no reason even if the battery is in or running off AC power please help me out mail me at dohcramg@yahoo.com
I had the smae problem with my Travel Mate 2420. At the end I realised that it was caused by an over heat. They said that I need to change the motherboard to fix it
Posted on Sep 17, 2009
Hi, does your laptop tuns off as soon as booting is finished and the main screen is on? If yes then your system is infected by some virus becoz i was also suffering from same problem few months back.I purchased a new antivirus "kaspersky" and my problem was solved.
Posted on Jun 17, 2009
My laptop wont turn on
I think your battery or your whole motherboard is fried. Does it make any noises? Do the fans start to run? Try unplugging your battery and only keeping your charger in.
Jun 02, 2013 | Acer TravelMate C300 14.1 XGA LCD Display...
The laptop would not boot up. It was hooked up to an external screen and then a few hours later, there was nothing on the screen. It wont boot up into a POST screen
Dead Laptop?
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Acer TravelMateĀ® C314XMi (G16012) Tablet...
Where is internet switch on a acer travelmate c110 tablet pc
On the acer travel mate only some models came with wireless and others did not. If yours has wireless the switch should be located right on the front of the computer. I hope this helps
Jun 23, 2010 | Acer TravelMate C110 Tablet PC
I have a acer travelmate c110 and I am trying to connect to a wireless connection but the wireless switch is not on and I do not know how to turn it on. Please help.
There should either be a physical switch somewhere on the side of the laptop or by using the FN + a certain key to activate it. Look at the F keys for an image similar to wireless then try that. If the above does not work, its probably turned off in the BIOS. Access BIOS and turn it on.
Mar 28, 2010 | Acer TravelMate C110 Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Travelmate C300
Sounds like it. . . (power pin problem). I use a Cable Retention Device like the one in this video to keep from damaging the fragile connector. . . .
Dec 07, 2007 | Acer TravelMate C302XCi-SP2 (TMC302XCISP2)...
Some keys of Acer Travelmate C 310 is not working
Replace the keyboard easily available for cheap. Get full manual at Acer website but replacement is easy, be careful of the clips holding the connection to the motherboard, don't remove just slide upward to release..
Sep 16, 2007 | Acer TravelMate C312XCi Tablet PC
Acer Travelmate 2200 laptop
Try taking the laptop battery out. You can remove the laptop battery by turning it over, you'll usually see some sliders at the bottom, slide them to the unlock position and you should be able to wedge your battery out. The battery usually comes in a very tall and thin rectangular shape. Once the battery is out, plug the laptop in through the mains power - this may solve your problem, if it does, you'll need a new battery if you wish to use it on the move. If it does not solve your problem, it is either a faulty power adaptor, or a faulty power supply on the motherboard of your laptop. A faulty power adaptor or battery is the best case scenario, as it's the cheapest to buy a replacement (although it's still expensive - $120 worth in the UK roughly). A faulty power supply on the mainboard generally means you'll need a replacement mainboard which is totally uneconomical, especially with the labour cost to fit it professionally. If the battery and power adaptor is not faulty, you might as well scrap it and get a new laptop. Good luck Tina!
Sep 07, 2007 | Acer TravelMate 302XCi Tablet PC
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Acer TravelMate C110 Tablet PC Logo
271 people viewed this question
Top Acer Tablets & eReaders Experts
Marvin
Marvin
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
