Question about Whirlpool Duet WFW9750WW White Front Load Steam Washer - WFW9750WW
Power went out door locked
All of sudden, power went out and door is still locked. Water is still inside. I tried to turn the power on and it doesn't work. I unplugged it for 10 min but still doesnt work.
    Habit-Forming:
  • 34 Answers
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Posted on Mar 31, 2014
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
Left front door lock doesn't work, neither with key or power
if the key turns inside the door lock and it still wont open its the rod inside the door panel that connets to your handles inner workings
Feb 03, 2013 | 2007 Cadillac CTS 3.6L
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
Aug 18, 2012 | 1994 Volkswagen Golf
My electrolux EWF 1074 washing machine suddenly doesn't start. When I load and press start button it changes to pause in a second, and it gives me error if I press start button again. There's no...
Hi jaejin_a_jun,
There are 3 likely causes.
1) Is the door firmly closed, it could be the door lock is not activated properly - Please check.
2) Is the Water open at the tap - Please open it fully
3) Is the Inlet hose or Outlet hose kinked? - Please straighten it
If these check out well, it could mean a possible component failure.
To check the drain pump (attached to drain hose at bottom) and Inlet hose (attached to inlet hose at top inner cavity) attached direct power to the 2 points found on each.
To chek door lock, check for power from the PCB to it via a Multimeter.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 12, 2011 | Washing Machines
I have a Maytag top load high efficiency low water washer and the lid lock is locked and will not open. I was doing a load of clothes and power went off for just a minute and now I can not get the lid to...
This is a common problem with a momentary power failure, the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". You will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Jul 05, 2011 | Maytag Washing Machines
I have a two month old Schlage door lock recently I went to get a new copy of Schlage keys. I tried it one time it work and a week pass suddenly my new keys doesn't work and even the original key, it...
Hello My name is Lori and I work at Schlage Customer Service. If this is not a Schlage Key it may be possible that they did not cut the key to the correct code. Look on your key for the 5-digit key code and make sure the keys align up exactly - the keys also should be the same width. Also when you install this B362 you should install it with the katch extended and the keys out of the cylinder. Try some of these tips and if you still need help - please feel free to call us at Schlage Customer Service: 1-888-805-9837 Good Luck!
May 13, 2011 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Hi Guys, I have a 2001 Expedition, it was running great, starting fine, drove it a half hour before all this happened. All of a sudden when I went to get in the truck all the doors were locked, and...
YES IT CAN SHUT IT DOWN. GET A GOOD FUSE TESTER, TEST ALL THE FUSES UNDER THE HOOD & INSIDE THE VEHICLE. TURN ON THE IGNITION SWITCH DURING THE FUSE TESTING
Jan 23, 2011 | 2001 Ford Expedition
Power locks stuck.... After a cold Christmas day,
should like water has frozen inside the door on the mech, its probely released by now , or water has cause a short in the door electrics
Dec 26, 2009 | 2007 Kia Sedona LX Minivan
Passenger sliding door doesn´t unlock (Power locks). When pulling the handle either inside or outside with doors unlocked it won´t open.
Sound like you have a dammaged door latch assembly. It is a pain but you have to take the insid door trim panal off to see what you are doing and make sure the latch assy is un locking. Dis connect power door lock motor linkage to make sure motot is not jaming the lock in the lock possition.
Oct 07, 2009 | Ford Windstar Cars & Trucks
Whirlpool Duet WFW9750WW White Front Load Steam Washer - WFW9750WW Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
