Question edited for clarity and add maker.
Question moved to a Fleetwood category.
I deleted the AI Autobot reply that you may have had a notification about.
You need rear view camera in back of car /truck.
This is attached to reverse light ,live and negative
and live run to the monitor while monitor earthed.
Just you tube it.
LUCK
Always refer to your owners manual, but if there is no key switch in the glove box, you probably have the sensor system which monitors weight in the passenger seat. If you have more than 30lbs in the seat the airbag is "on" and the sensors are activated. Otherwise the passenger side is off if the seat is empty.
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed. You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor. First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
have you made sure the video cable is plugged into the screen and the back of the computer correctly. You could also try a new video cable, because the problem may be that the wires inside the video cable have frayed. If that doesn't fix the problem you could try using a different monitor and see if you can replicate the same problem with a different monitor, if you can, the computer may have a problem with the graphics card. If you can't replicate the problem with a different monitor, it seems as though your northgate innovations monitor has developed an internal fault, if the monitor is within warranty try and get a free repair or get it replaced (if you have the receipt.
Does this leak have a color to it? Take and dip your finger in it and put it on a clean white piece of paper. What color do you see?
Regards,
Tony
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
