Question about Miele Olympus Canister Vacuum Cleaner, S2121 Olympus S2 - Lotus White
Cant get it apart
Cant get to the motor to see what is wrong with it
  • Miele Master
  • 3,878 Answers
Depending on the problem, it could be the thermostat this is next to the motor and if you are have trouble getting to the motor it has probably over heated and the plastic has melted together. cant get it apart - f683d177-8e92-4e7a-9620-efc9a6f06100.gif as you can see the motor is in a small place and has a plastic case over the top the motor comes out through the top, hope this helps
Posted on Apr 03, 2014
Replacement motor
Did you check out ebay? Google it.
Mar 02, 2016 | Oreck XL Professional Air Purifier
Oreck SL will not work on medium setting
Either your switch is not making a contact internally or the wire that runs from the motor to the switch is loose or not connected, or that speed is burned out on the motor. Those motors have a separate wire for each speed, so it's either not getting power to the motor from the switch or the that speed setting is burned out on the motor its self. I would just work around it and use the low or high setting until you can take it apart to test if the motor is getting power from the switch, if so then the motor is bad, usually the bearings go out on the motors before the wiring does. Unless your motor was on medium and was stopped for a long period and overheated that setting which will melt the wires and cause it to not work. They have a safety switch on the motors now to keep this from happening.
Jan 12, 2015 | Oreck XL Professional Air Purifier
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Jul 22, 2014 | Electrolux Band Aerus Lux Legacy Canister...
Why would new fan motor blow the air backwards
Lmfao at Ken, dude this is a single phase 120 vac motor. You can close your eyes and pick one there is no switching of wires to the motor. YOur hot can go to which ever and your neutral can go to which ever. DOES NOT MATTER :-P don’t reply unless you know blow horn. But just a heads up you can Reverse rotation very easy...
Apr 29, 2014 | Alpine Air XL-15 Air Purifier
Air purifier won't oscillate anymore... How do we fix that?
My is no longer oscillating as well. Took it apart and feel like its the small motor. I am unable to find it online. will call honeywell tomorrow. And probably bring the motor somewhere to ask what optional motor will work in its place. And put it all back together. a new motor should be about $10
Jan 09, 2014 | Honeywell Hfd-120-q Quietclean Tower Air...
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
Pure pro fan motor
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
Oscillation stopped working!
Sounds like the drive gear is stripped.
Nov 20, 2007 | Bionaire BAP1500-U Air Purifier
Miele Olympus Canister Vacuum Cleaner, S2121 Olympus S2 - Lotus White Logo
85 people viewed this question
Top Miele Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Miele Air Purifier Expert? Answer questions, earn points and help others
