Question about FIC K7MNF-64 nVidia nForce 2 Socket A mATX MB w/Snd, VID LAN Motherboard
Constant tone when operating
Computer emits a constant tone when running. Display and computer seems to function properly but the tone exists. What causes this and should I be worried?
  • 1 more comment
  • david_lovern Jun 15, 2009
    The tone also exists when the computer is shutdown with power still supplied to the Power supply. Is this still the same issue?
  • david_lovern Jun 16, 2009
    All memory and the graphics card were removed and the low constant tone did not stop.
    I removed the battery and unplugged for >10 mins. I even used air to blow out the slots. After restoring the system the low constant tone is still present. Upon startup the tone sounds like a modem connecting then shifts to a low constant tone. The computer seems unaffected. Initially I said it was a constant tone and you called it a beep. It is not a beep at all. It is more like a constant siren wailing but at at very low level. What is the next step, if any?
  • david_lovern Jun 17, 2009
    I looked into the bios and could not identify anything that resembled chassis intrusion alarm. If it is in the bios I could not locate it. What do you suggest?
  • FIC Master
  • 4,806 Answers
A constant beep usually indicates that there could be a loose card in the case, check that memory is seated properly, also check your graphics card and any PCI cards that are inside the case are seated properly.
Good luck
Posted on Jun 15, 2009
  • Lee Hodgson
    Lee Hodgson Jun 15, 2009
    while the computer is off start to remove the memory, graphics card etc and see if the beep stops.
    If it still beeps remove the motherboard battery and the power cord for 10 minutes, then put back all the components and last of all the power cord, see if that helps.
  • Lee Hodgson
    Lee Hodgson Jun 16, 2009
    The only thing i can think of it being now is the chassis intrusion alarm, you can disable this by going into the bios and stopping it from sounding.
    Try that!!
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
Mar 05, 2018 | Taylor Ice Cream Makers
Computer monitor cycles on and off when the computer boots up but seems to have constant power when just turned on
The boot process goes through various display modes. Each time it switches, the monitor has to set itself for that mode. This causes the monitor to flicker while it's adjusting. Perfectly normal operation.
Sep 02, 2014 | Acer Computers & Internet
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
My hp w1907 monitor is constantly auto adjusting every 1 or 2 seconds. Make it stop.
Good morning! Auto adjustment occurs when resolution or refresh rate of the display changes. Check your display setings in OS. Set them properly according to product operations manual. Update your display adapters driver. Also check your VGA card or motherboard display port & try using a different cable. try pluging the monitor to a different computer or plug in a different monitor with your motherboard or VGA cards display port. best regards
May 03, 2009 | HP w1907 LCD Monitor
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Canon MP780 has gone crazy!
Issue: Unable to send faxes
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
were the copies from the computer or something you tried to copy before?
Nov 11, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
154 people viewed this question
Top FIC Computers & Internet Experts
David
David
Marvin
Marvin
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
