Question about Aqua 2002 Rlc 13 1967 Dodge Charger Aqua 10k
2013 dodge charger
Fuel hole opening is blocked by metal flap and will not move. how do I fix?
Just got a 2013 2.0 TDI call for a diesel stop cover plate would not flick open when I tried to press it down low on diesel still can't open it
At this time, you might want to use a flat head screw driver or plastic ruler to gently pry open the fuel flap door. When you press the release button, do you hear the actuator moving on the rear passenger side ? If yes, might need a new cable that runs from actuator to the fuel door flap.
If not, then first thing you may want to do is check for current at the actuator while you have someone pressing the switch. If you are getting power, then the actuator is bad. If no power, check fuses and go from there.
Jan 08, 2017 | Cars & Trucks
Gas metal flap want open on my 2012 Dodge Charger
catch solenoid release point ..bit dry may need machine oil or hinge a bit of tweaking
How to Open Fuel Door on 2011 Dodge Charger
Oct 24, 2016 | Dodge Cars & Trucks
Why would the metal shield on my 2013 jeep Cherokee gas filler lock up? I can not put the gas nossle into the hole to put gas in the car?
It sounds like something is jamming the spring mechanism. If you cannot get it open, take it to a mechanic for assistance.
Mar 09, 2015 | 2013 Jeep Grand Cherokee
Where is the manual trunk release located for this?
As in your button is failing? open back seats and pull emergency internal release, or use key
Jan 19, 2015 | 2013 Dodge Charger
do you mean in the filling pipe , this is usually just depressed when putting nozzle in when refueling try giving it a push with a blunt tool and see if it will open
Mar 30, 2014 | 2013 Dodge Charger
Fuel sensor
Yes, the flap must seal the hole or the Vapor system will generate an error code. The Flap may be damaged or the spring has broken or as you mentioned, if it's really cold, could be frozen open. Use a flashlight to examine the filler hole and see if the flap is still there. How to fix ford fuel fill inlet problem
Oct 18, 2017 | Ford Taurus Cars & Trucks
How to test a FUEL TANK SENSOR in 2013 Dodge Charger??
a dodge toyota, , is this an engine swap? or?
the fsm shows this.
and so does alldata.com.
generic answer..........!
tank full , sender reads say 10 ohms
tank empty 100 ohms.
0 is shorted
infinity is open (bad)
Dec 05, 2013 | 1998 Toyota Camry
My car just recently did this and wanted to know if u figured out the problem
Feb 22, 2013 | 2011 Dodge Charger
How to remove the fuel filler neck on my 1999 Dodge Grand Caravan 3.8 ltr. engine
OPEN GAS CAP FLAP THEN YOU NEED TO DRAIN GAS BELOW FILLER NECK.THEN LOOSEN REMOVE SCREWS IN THE GAS CAP FLAP AREA WHERE FILLER TUBE CONNECTS THEN GO UNDERNEATH VAN LOOSEN REMOVE HOSE CLAMPS AND REMOVE THE HOSE AT THE FILLER NECK BELOW THE GAS TANK.SPRAY WD40 AROUND HOSE AREA AT METAL FILLER TUBE STICK OUT GAS TANK.CAREFULLY USE LARGE PAIR OF CHANNEL LOCK PLIERS TO REMOVE WORK HOSE OFF METAL TUBE FROM GAS TANK. IF YOU CANT REMOVE HOSE WITH HANDS.BECAREFUL NOT TO MAKE ANY SPARKS.PLACE RAGS AROUND ANY METAL PARTS TO KEEP CHANNEL LOCKS FROM HITTING METAL MAKING SPARKS.
Jun 23, 2011 | 1999 Dodge Grand Caravan
The tiller keeps stopping even before it is in use. Is it a choke problem?
Hi, your choke could be a problem. Sometimes the the metal flap falls down and blocks the carb. There is a small fitting for an allen wrench to tighten the flap so that there is more friction when you move it. Also, make sure that your fuel mix is correct and that there is nothing wrapped in the cultivating tines.
Nov 15, 2010 | Mantis Garden
Aqua 2002 Rlc 13 1967 Dodge Charger Aqua 10k Logo
Top Aqua Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Aqua Toy Expert? Answer questions, earn points and help others
