Question about Craftsman 10" Table Saw
Table saw turns off after one second. Won't stay running.
Turn table saw on and it runs for a second.
    Problem Solver:
  • 8 Answers
You might need a new switch
Posted on Apr 06, 2014
  • Dave Vuckovich Apr 29, 2014
    In an electric motor there are start windings and run windings. When the motor first starts in is running on the start windings. When it gets up to the proper speed a switch inside the motor will switch to the run windings.It is fairly simple to replace. A good electric motor shop can make this easy repair and it will be much less than the cost for a new motor.
rowdy45176
  • 2176 Answers
SOURCE: Looking for owners manual Craftsman table saw 101.02141
I tried their site and they say no parts available for that tool, They suggest that you call them direct and I have a phone number at 1-800-252-1698 and they might be able to help. Good luck
Posted on Mar 30, 2009
  • 360 Answers
SOURCE: no book.how to square craftsman table saw mod 137 blade to table
Thanks for using Fix Ya
To download the owners manual for your saw, click --->here<---
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 15, 2009
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
SOURCE: saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Posted on Apr 28, 2009
protek480
  • 1714 Answers
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
Posted on Sep 22, 2009
Motor won't stay running
This maybe the Run capacitor. If not handy, remove and bring to a motor shop as some capictors are internal!
Mar 07, 2013 | Delta X5 3Hp Left Titl Unisaw with...
I plugged in my table saw and everything worked just fine. I unplugged it, and then came back a few minutes later and turned on the table saw again. This time the motor was not running. Power was getting...
First of all, how did you determine that power was getting to the motor? If you can test for power with a voltmeter at the motor connections themselves and show power then the switch is OK and the circuit breaker is not tripped. Turn off power and attempt to turn the blade " CAREFULLY" and if it moves easily then the motor is probably defective and will have to be replaced. After turning the motor and finding it easy to turn, then turn the power back on and try to start the saw again. Be carefull because the saw may start. If the blade will not turn then the motor is definitely defective and will have to be replaced.
Good Luck!
Mar 14, 2011 | Craftsman 10" Table Saw
I can no longer raise or lower the blade on my 10" sears table saw' model # 113.298032.
After some use the threads on the raising mechanism can become clogged with sawdust and resin.
UNPLUG the saw and look underneath up inside the box. there is a rod that runs from the wheel you turn to raise and lower the blade into the actual mechanism. Brush it clean and give it a good douse of WD40 to help clean it. That rod must turn freely so look for any obstructions that will prevent that from happening
Jan 18, 2011 | Craftsman 10" Table Saw
Table saw cuts off
Probably the overload trip is set to too low a current. Either this or it is faulty.
It is just possible that there is dust in the contacts which causes a bad contact but it is more likely to be the overload trip.
Jun 02, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Does not turn on. The wood was at an angle and jammed when it quit working
Hello. I recommend that you check your circuit breaker or fuse which is in the house panel and feeds the outlet that your saw is plugged into.
I believe that you will find that you solution is to reset the breaker or change the fuse.
Nov 28, 2009 | Craftsman 10" Table Saw
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
Table saw capacitor heats up and explodes.
The wrong capacitor for one thing. There are starting caps and running caps. The starting cap is in the circuit for only long enough for the motor to get up to speed. If you have a Leeson motor that has a start and run cap then the run cap may not be the correct on. If you have a start cap blowing out I suggest you check the centriifugal switch in the end of the motor. It may have welded the contacts shut. In any case, I would take it to a motor shop .
Mar 11, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Nov 25, 2008 | Bosch 4000 - 07 Electric Table Saws
Craftsman 10" Table Saw Logo
137 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
