Question about Zhone Computers & Internet
Hi, I have a Zhone 3200 EtherXtend device but dont have any idea about it. I want to configure it so that I can make calls. For this I want to log into it but have no idea how to do it. Basically I ha
To male calls
  • Zhone Master
  • 3,320 Answers
It's not a phone.
Posted on Mar 31, 2014
Testimonial: "I know that its not a phone but it has 4 voice ports and hence I would like to use them to make calls which connects to the call manager, any suggestions how to configure the voice ports will be highly beneficial and as I said I have a Zhone EtherXtend 3244 device, Thanks"
  • Mohammed
    Mohammed Mar 31, 2014
  • 128 Answers
SOURCE: email the Status log
The Log settings option allows you to save and email status logs to an administrator?s email address. Step 1 Open a web browser and type the IP address of the router (default:192.168.0.1). The username is admin (all lower case) and the password is blank (nothing) Step 2 Click on the Status tab and click the Log button. Step 3 Click on the Log Settings button. Enter the SMTP Server or IP Address in the field provided. Example: SMTP server > smtp.email.msn.com IP address > 207.46.181.11 Step 4 Enter E-mail Address in which you want the logs to be sent to. Step 5 Select the Log type you wish to send to your SMTP server. System Activity Debug Information Attacks Dropped Packets Notice Step 6 Click on Apply and then click Continue to save the changes. Click the Send E-mail Now button to send the log to the e-mail address specified.
Posted on Feb 16, 2006
peglegcards
  • 89 Answers
SOURCE: configuring security for my router
Hello, Put "admin" in for ID and Password both. Some routers require both. Hope this helps.
Posted on Feb 25, 2008
rickatnight1
  • 72 Answers
SOURCE: where can i log on to the router or change its password?
To access the router's configuration you need to type its IP address into a web browser. The default IP is 192.168.1.1 but if that doesn't work you can find it out with the following steps:
  1. Go to Start->Run
  2. Type "cmd" without the quotes into the box and press Enter
  3. type "ipconfig" without the quotes into the larger black box and press enter
  4. The number across from the "Default Gateway" is your router's IP address
I hope this helps!
Posted on Jul 09, 2008
acdr
  • 1913 Answers
SOURCE: Cannot log onto my router to configure it
also try 192.168.1.2
or 192.168.0.1
or reset your router it is inback side 1 reset button press it for 15 seconds.
Posted on Mar 25, 2009
acdr
  • 1913 Answers
SOURCE: can't log into 192.168.1.1
try with
http://192.168.15.1
or http://192.168.0.1
or if u still not access u have to reset it.
reset button is in back side of router press it for 10 seconds.then it reset to daults.
Posted on Apr 06, 2009
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is...
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Mar 17, 2011 | Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM...
How to configure router zhone 3400
Here is the user manual for your router: www.psitec.com/manuals/etherxtend/ethx3400-11501000UG.pdf
It should help you set up and configure your router. Good luck!
Feb 28, 2011 | Zhone (6218-I2-200) Router
Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address (192.168.1.1) into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
Dec 21, 2010 | Zhone (6218-I2-200) Router
Unable to get log in page for modem
try doing a Google search USUALLY the address is 192.168.1.1 if your running xp or higher look for the command prompt icon it is in the start menu under acessorys the type ipconfig it should give you a number for your gateway or call up the manufatures tech support
Jun 29, 2010 | Zhone (6218-I2-200) Router
Accesing internet at low speed at zte dslam
Using Zhone EtherXtend with both E1 and SHDSL lines has enabled delivery of higher bandwidth Ethernet business services in Finland
By using an easy-to-install Ethernet Access Device (EAD) coupled with cost-effective Ethernet Aggregation, a UNE-P can be transformed into a 5.7 Mbps Ethernet connection, with multi-pair loop bonding increasing bandwidth to over 45 Mbps.
Ethernet over Copper is used in carrier networks for business services ranging from T1/E1 to SHDSL and DS3 rates.
T have quoted the above from : http://www.zhone.com/solutions/ethernet/
___very hard pressed for time, Sorry........sodeep
Oct 26, 2009 | SMC SHDSL 6PORT ETHERNET EXT/DSLAM...
Where can i log on to the router or change its password?
  1. Go to Start->Run
I hope this helps!
Jun 13, 2008 | Zhone (6218-I2-200) Router
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Computers & Internet Logo
42 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
