Question about Creda Ovens
Creda problems 3 of the cooker rings dont seem to adjust they are either off or on full with no adjustment in between. Can you help? Iain
  • 20 Answers
Hi, if there is no regulation on the hob, it is typically the switch that is faulty unless halogen, then it could be the thermal cutout.
warmest regards
Richard The Repairman Colchester Oven Cooker Washing machine repair
Posted on Mar 31, 2014
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hi.i have a hotpoint creda c362e cooker the rings
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Posted on Jan 09, 2010
  • 40 Answers
SOURCE: creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Posted on Apr 07, 2010
rickead1
  • 1998 Answers
SOURCE: i didnt get a user manual with my creda cooker
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Posted on Apr 29, 2010
SOURCE: Canon Carrick LPG cooker-failure of
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Posted on Jan 08, 2011
Where do i find batteries for ignition in my creda expression l152g gas cooker ?
Not normally batteries, most are mains powered, but your is a single AA battery. The manual states;
The battery is not covered by the guarantee. Use an alkaline AA battery. The battery holder is located in the plinth panel below the oven door. Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to the battery. Fit the new battery with the end marked "+" on the same side of the battery holder as the red lead. Replace the battery holder by pushing it firmly into the hole in the plinth.
The spark unit is usually under the hob on the left side. Check the connections as they can get really messy and even break through. Also spray the igniter posts with oven cleaner and leave for an hour, clean off with a plastic brush and water. Dry thoroughly. On the hobs, remove the burner and wash them, the underside as well as they rely on the earthing through the aluminium ring, remove and clean that too.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HBC150GG.pdf
Feb 17, 2018 | Creda Ovens
Every time I switch the rings on my creda starlight cooker they start smoking and trip the electric ?
they are shorting out through the ceramic insulation
get and install new rings
Dec 31, 2016 | Creda Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
Dec 01, 2010 | Ovens
I didnt get a user manual with my creda cooker dont know how to set the timer
hope this helps
Apr 28, 2010 | Ovens
Creda cf50g cooker oven not getting hot
Apr 06, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Ovens Logo
136 people viewed this question
Top Creda Ovens Experts
Craig Butler
Craig Butler
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Creda Oven Expert? Answer questions, earn points and help others
