Question about Sigma Sport BC 16.12 STS CAD
Display will not come on
I replaced battery and still blank
  • Tina Nelson
    Tina Nelson Mar 30, 2014
    i just installed the wireless system, the computer will not turn on
I have a fujitsu a/c unit. Remote Model AR-RAH2U. If I push the on button, the a/c goes on-screen remains blank. I can not adjust the temperature or anything else. I have replaced the batteries.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display.
Hope answer the question
Aug 07, 2016 | Fujitsu Heating & Cooling
Blank Screen
Remove and install new batteries, if displays reprogram. if no display replace thermostat
How To Install Programmable Thermostat The Home Depot
Jan 20, 2016 | Televison & Video
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
Model S400CA-CA006H, Power ON, only back lit blank display. Battery icon is green while the BULB icon LED is orange in colour.
  • rjsymmes has the most accurate solution. Start with a battery replacement. Next course of action is to use a Bootable Media Source (Windows Disk or Recovery Disk) to see if the laptop responds and can have the Start Up repaired. If a Boot Media fails, then examine RAM, Hard Drive removal, then boot. Last resort Motherboard.
Jun 22, 2014 | ASUS Computers & Internet
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
My unit keeps chirping every 30 seconds even after replacing the batteries. The unit is over 5 years old.
The manufacturer has written this in their manual for your unit...
"Err" displayed -battery icon may show any state of battery capacity. One quick beep every 30 seconds. Unit is Error condition
Replace batteries. If "Err" (or blank display) continues, unit has malfunctioned. Replace immediately.
Link to manual...
http://portalgb.knowledgebase.net/utility/downloadArticle.aspx?aid=294720
Feb 03, 2011 | Kidde Nighthawk 9000089 Carbon Monoxide...
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 | Watches
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
Sigma Sport BC 16.12 STS CAD Logo
122 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
