Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
Kscs25inss00 thermistor The evaporator fan motor is cycling on and of rapidly every few seconds. The rate is inconsistent. When I remove the cover over the fan in the freezer it runs steady, but a couple of minutes after re-assembly it starts to run intermittently again. Is this the thermistor causing this?
  • KitchenAid Master
  • 842 Answers
The answer to your question is its possible but unlikely. Th thermistors report information to the electronic control only, they can't control anything, so if your fan motor is failing this ramping would happen as its a variable speed fan. Lastly if you motor is variable as I see, its possible the electronic control would also need to be replaced. I would change only the fan first and see if you would need to go further. Part# W10255195 is the part for your unit. Good Luck
Posted on Mar 31, 2014
projdoc
  • 2237 Answers
SOURCE: KitchenAid refrigerator model KSSC48QMS00, evaporator fan runs 24
is the compressor running too? if not, the relay is stuck.
Posted on Nov 12, 2009
  • 73 Answers
SOURCE: KitchenAid evaporator fan replacement
the correct procedure is to hold the motor n pull the fan blade out holding from the central n removing the clips if any.it should be replaced if its worn out
Posted on Jan 18, 2010
heatman101
  • 43501 Answers
SOURCE: I have a KitchenAid KSCS25FKSS00
Yes, you need to replace that fan...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Testimonial: "Good additional insight. Fast response."
  • 1891 Answers
SOURCE: My refrigerator is a Kitchenaid KSRG25FKSS05 and
refergerant is not causing this problem. when the comp starts up and the bottom fan also starts up and the fan in the freezer comes on / this alll happens whe the cold control said we need more cold . so it sounds like the one that won't come on is the comp . and the clicking noise is the thermal control shutting down. then when cooling tryes to restart. . the kit you need is 8201786 this is called a start device and comes with instructions .. cost about $70.00 . easy to install . mm hope this helped and thanks for the model # .. and for ysing fix ya ..mm feed back pls
Posted on Nov 17, 2010
heatman101
  • 43501 Answers
SOURCE: I have a KitchenAid KSRS251
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Posted on Mar 18, 2011
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Why is the Rinse Cycle and Drying not working
Unfortunately you did not specify the model dishwasher so I'll give you a general answer.
(The indicator light, straight from Washing moves to completion stage where the light blinks rapidly) I believe you means the "End LED" (LED 3) blinks rapidly. If this is true and according to your description of failure (no drying, no rinsing) I think that appeared alarm AL04. It means the thermistor (NTC) not compliant - probable failure of the component that detects the temperature .
I suggest you to check: thermistor NTC, wiring and electronic.
24464652-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Rapidly flashing any combination of four LED diode means failure.
Dado
May 20, 2014 | Ariston Technologies Dishwashers
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
Control lights ( temperature readings etc ) are consistently blinking on and off, accompanied with a beeping sound
Main control board is over
temperature. Look for blocked condenser air flow or inoperative condenser fan motor.
Refrigerator over 48°F or
freezer over 15°F for 3 hours.
Run diagnostics and test operation of all components.
Both thermistors failed.
Run diagnostics and test thermistors and thermistor leads.
No feedback from evaporator fan
motor. Run diagnostics and test fan motor and/or wiring. The manual is HERE
Jan 29, 2010 | KitchenAid KSSC48QMS Side by Side...
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
Hello, I own an Admiral Refrigerator (Admiral Ultima 2000) and the evaporator motor occassionally squeals. If I turn off the refrigerator for a while and turn it back on a few hours later, the fan will run...
Motor bearings are more than likely going out. The fan spins until the bearings heat up. Suggest you replace motor take model and serial number to get part at the appliance parts house Good Luck
Dave
Jul 29, 2009 | Refrigerators
The freezer (top) is freezing cold, bottom is not cold
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
5. Another problem is the condenser fan motor may be out...it is under the refrigerator...and can be accessed from behind the refrigerator......be careful as you pull the frig out as water lines are attached...(generally)...if motor is fine..check to make sure there is not a lot of dust and or dirt accumulation around the condenser coils...if there is clean them with a shop-vac ....dirty condenser coils can cause ice build up also...since the condenser removes the heat evacuated from the freezer.
6. And the final problem is ..it could be a restriction in the evaporator line...(though this is rare)...if you pull the cover off of the back of the freezer and find ice in an isolated area of the evaporator...it could be a restriction...it will most likely have ice all over the evaporator.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..thanks for rating my effort.....The Fang
Apr 22, 2009 | Whirlpool Refrigerators
Evaparator motor access
Yosh, you are going to get it from the inside of the freezer. Lift the whole door off to get it out of the way. Remove the ice-maker if there is one by removing the quarter inch screws holding it in. Unplug the harness. The vent grill has two clips toward the top side that push inward and it pulls off. Remove the quarter inch screws holding the back panel in place. Remove the thermistor cover on the right by pushing in on the tab and remove the thermistor from the cover (slides out). Now you can remove the back panel. The motor is held in with a plastic mount that will push in and release from the bottom. Pull the fan off first. Careful of the sharp evaporator fins, easy to cut yourself. It's ok to bend them a little just straighten them out when finished. Take your time and observe...this is not a hard job...Catriver..post back...This is for model starting in 596.
Dec 18, 2006 | Kenmore 73502 / 73504 / 73509 Bottom...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
