Question about Dryers
Lg 2524 won't start just clicks
Dryer has power, but when you press the start button it just clicks.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Try changing the capasitor
Posted on Apr 09, 2014
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
  • 148 Answers
SOURCE: kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Posted on Jan 04, 2009
  • 9 Answers
SOURCE: Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Posted on Aug 02, 2009
MNTECH
  • 1543 Answers
SOURCE: LG DLE5977W dryer trips circuit breaker
You could set the dryer to manual dry and then no heat and see if the result is the same. If it runs then, you have a short in the heating system somewhere. If it still kicks out the breaker, you've got even worse troubles. Most likely an electronic board, and what ever caused it to go, like maybe still a heating system issue. I*d suggest calling a qualified service tech for this one. In the USA, you can find one at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
Posted on Aug 06, 2009
heatman101
  • 43501 Answers
SOURCE: MY LG DLE2050W DRYER WILL NOT START BY PRESSING
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 28, 2010
My lg dryer want start up it just clicks three times when I press the start button
On older models the selection switch starts to wear out, click both the selection switch and timer switch around in a full circle & try starting again. If it is an electronic model, try unplugging it and let it sit 10 seconds then plug it back in and see if it reboots properly. A power outage or brown out may have effected it.
Nov 12, 2016 | LG Dryers
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
When pressing the start button on my LG DLE2514W dryer it makes a clicking sound and will not start ???
heatman101
Jun 26, 2011 | LG DLE2514 Electric Dryer
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
MY LG DLE2050W DRYER WILL NOT START BY PRESSING POWER BUTTON. POWER AND CORD ALL HAVE BEEN CHECKED AND IT IS FINE
heatman101
Oct 24, 2010 | LG DLE2050 Dryer
Need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Dec 30, 2007 | Washing Machines
May 23, 2007 | LG DLE2512W Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
