Question about Saeco Vienna Plus Espresso Machine
Saeco vienna plus wont turn on, no light
Machine stopped working in the middle of a cycle.
SOURCE: Saeco Vienna: water does not go through to the main unit
I had the same problem and got on the Saeco US website and talked to an online support person. She downloaded me a couple of pages of "fixes", I tried them and they worked! You have to take the two screws out of the brew group, remove the spring and a little clear plastic ball. Then clean out the hole thoroughly. I stuck a toothpick up into it from underneath to clean out the coffee that was stuck in the hole. I then put it back together and now it works perfectly.
Posted on Aug 02, 2008
SOURCE: Manual for Saeco Vienna Super Automatica machine
Here is a link to the manual
www.powner.name/vienna.pdf
Posted on Jan 04, 2009
SOURCE: saeco wont stop descaling
In service menu there are 2 parameters you should look. First one - descaling - should be on 'done'. The second one is a counter - water used since last descaling - should be on 0.
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: where can i get my
Purple Turtle Coffee
211 W, Main St
La Porte, TX 77571
281 470 6555
I just picked up my repaired Saeco expresso machine. The people that work here are very professional and spent a lot of time with me showing me how to properly clean my machine. It was about a 30 minute drive east from my house near the Galleria but it was WELL worth it. I say that as I sip on some homemade Latte - yummy!
Posted on Apr 29, 2009
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
Why my saeco vienna plus coffee machine does not turn on
A little more info would be helpful. When you say" turn on" do you mean there is no power or do you mean the machine will not cycle when the brew button is pushed? Also, is the red light on if there is power? If there is no A.C. power that would mean the fusible link or
thermistor has opened. Do of course make sure there is power at the outlet, even experts get fooled by panel breakers being tripped ha!
Jun 16, 2014 | Saeco Vienna Espresso Machine
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
My brew unit has dropped a wire and the dreg drawer cannot be withdrawn on Saeco Vienna Plus
The machine is in the middle of a cycle, and needs to be reset. Put all of the parts back in and turn on the machine. See if the machine moves back into the normal position.
if it does not then you need to service the unit.
Service Center of New York.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 06, 2013 | Saeco Vienna Plus Espresso Machine
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Need to take out brew group jammed
Hi
Apr 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Coffee is not coming out
take out the brewing unit and clean it.
Make sure all parts is on place, try to open the steam knob and make a full cup of water (tea).
Let me know if you need more help
Best regards
/Mirran
Sep 24, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna Deluxe grinder doesn't work properly
Try to open the steam knob and make a cup of water.
Make sure everything is in place.
One more thing you can try is:
open the door, take out the brewing unit, driptray and dregsbox.
Look in the machine and you will see three hole, one in the lower left corner, one in the middle above the driving shaft and one in the right upper corner.
Turn on the machine and put a screwdriver in each hole and see if the lights go off.
Hope this will help you.
/Mirran
Sep 02, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna silver is not heating
Try to descale the machine to see if it helps, i think you have calcium in the boiler.
Best Regards
/Mirran
Aug 29, 2008 | Saeco Vienna De Luxe Espresso Machine
Open Questions:
See all Saeco Vienna Plus Espresso Machine Questions
Saeco Vienna Plus Espresso Machine Logo
50 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
