Question about Bose Lifestyle 28 System
No sound I have gone through all of the suggestions and checked out all the connections, etc.. It appears that the Acoustomas unit will not come on, it was working in the morning but no sound in the afternoon.
  • 30 Answers
Sometimes it is as simple as pulling the powerplugs of the system and then powering it up again. This resets the system and may get you going again. Also make sure that the cable between the center and the bass module is well plugged in. to be sure unplug and replug on both ends. If that does not work your unit needs to go back to Bose.
Posted on Mar 31, 2014
Buetooth hands free car kit
Hi Peter,
Can you confirm which radio you have and also type of phone, Iphone, android or windows -etc.
Do you want to play music through the radio or is it just the phone connection?
Sounds like you may need to look at the bluetooth frequency's used ie 4.02 and 4.04 - if you can go into sub-menus on bluetooth settings there is an option usually to 'use another voice connection' or something similar - it sounds like one or the other unit is using 4.04 and the other 4.02 - so they connect but the audio element isnt syncing together - Check 'about' bluetooth on your phone - it may tell you if it uses 4.02 band or 4.04 - I would suggest if you knock all settings to the older 4.02 , then things should sync up fully - its the older technology standard, - hope this helps.
May 28, 2015 | 2005 SsangYong Rexton
I have a bose acoustomas system. It does not have HDMI inputs on the bose amp which denies me hooking a blu ray dvd to the system to access sound for the speakers thru the amp. I want to have dvd and hdmi...
Simple.Depending on the number of HD gadgets you have,you need either 2 or 4 channel HDMI converter.Connect the HDMI output to your tv and connect other equipments to the various HDMI,VGA,component and composite inputs,including your Bose System.
Dec 04, 2013 | Bose Audio Players & Recorders
We cannot get sound from our system. We have tried every suggestion in the troubleshooting area from the instruction book. Everything appears to be working except we get no sound. We have checked the...
817-336-2491 fort worth chamber of commerce,, ask them for people who can repair or instruct you on this issue, or for recommendations on where to go
May 02, 2011 | RCA RS2600 CD Shelf System
The TV doesn't power up anymore - i've checked the cord connection, made sure the power switch is in the "on" position, etc. basically ran through all the possible troubleshooting solutions. ...
If power reaching unit and after all you have checked, it appears the PS is fubar. Easiest thing to do is check for swollen/leaking/blown capacitors and replace them - cross your fingers and turn on.
Sep 04, 2017 | Maxent MX-26X3 Television
All sound has gone windows xp need it back how?
YOU NEED A SOUND CARD.WHEN YOU INSTALL WINDOWS XP ITS NOT GOING TO HAVE ALL THE FEATURES, INCLUDING NETWORK CONNECTIONS,SOUND GRAPHICS ETC.MY SUGGESTION IS GO TO YOUR LOCAL COMPUTER REPAIR SHOP AND ASK FOR THE PROPER SOFTWARE THAT IS COMPATABLE WITH YOUR MOTHERBOARD.OR JUST HAVE THEM DO IT FOR YOU.I HOPE I HELPED YOU BYE.
Nov 27, 2009 | Microsoft Windows XP Home Edition
Irregular performance...
sounds to me like your laser is gone.
Some discs are harder to play than others as some are multilayed, check online as to whether it is suitable to use laser cleaners these are like discs with soft brushes attached, you can get them from pretty much any computing place, i wouldnt know whether its sensible to use on a DVD player, but couldnt hurt anymore eh?
Jan 08, 2009 | Sony DAV-S500 System
Loss of volume
About 6 months ago I had to wipe my hard drive clean and then reinstall all disks for my Dell Dimension 4500 system. Ever since then, there has been no sound for emails, music, Start-up and Logging off etc...etc.
When trying to play a cd for instance, or anything requiring sound, the following message appears:
media_player9.gif 0xC00D11BA: Cannot play the file Windows Media Player cannot play the file because there is a problem with your sound device, such as a sound card or sound controller. You may encounter this error message for one of the following reasons:
  • Your sound device is in use by another program. Quit other programs that may be using your sound device, and then try to play the file again.
  • Your sound device is not functioning properly. To troubleshoot the problem, see the Sound Troubleshooter in Windows Help or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again.
Error ID = 0xC00D11BA, Condition ID = 0x00000000 Web Help
________________________________________________________
There are no other programs running and I have repeatedly gone to control panel and gone through all the Windows sound trouble shooting suggestions regarding sound devices. All wire connections have been checked and there was no change in regard to the plug-in areas.
Everything worked great soundwise prior to re-installation, no wires or connection locations were changed, and no one else has used my computer so I have ruled out any accident by another person.
Please call me or email me at l.bassing@att.net, Phone is 551-497-2795 to help me while at my computer. It will be so much appreciated. This problem has been driving me crazy for too long.
Thanks so much for your prompt attention and looking foward to speaking to a tech repair adviser asap.
Sincerely,
Lauré Bassing
Oct 21, 2008 | Harman Kardon HK695 Computer Speakers
Pioneer deh p9800bt
There is a yellow wire that needs to be connected to a constant +12 volt supply. This wire retains all of the pre-sets, settings, etc.
It sounds like it is not.
Check the connections with a volt meter with the vehicle off to verify it has constant +12 volts.
Best of Luck.
Nov 13, 2007 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
N3230-no pictures appearing on LCD
i also encountered such problem.. try to open and check the connections from the lcd, this maybe loosen.
Aug 30, 2007 | Nokia 3230 Cellular Phone
Bose Lifestyle 28 System Logo
52 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
