Not really a problem as much as a question. I have brand new image dynamics cx65 6.5inch 2 ohm speakers, how long is the break in period for the woofers
That pretty much sums it up, i just wanna know how long i should break thes in for before i play them in normal situations
    Top Expert:
  • Computers & ... Master
  • 26,637 Answers
There isn't one. A loudspeaker runs from new.
Posted on Mar 31, 2014
So I just bought a kicker cx 300.1 mono block amp to run my 10 inch comp d 4 ohm 300 watt sub. I ran it parallel and it smells like the coils are burning. Help
That's only normal for the burn in period. Make sure you're not running it in 2 ohm by wiring the sub wrong. That amp is not really 2 ohm stable for a sustained period
Feb 03, 2015 | Kicker Car Audio & Video
Can i run a 4ohm.dvc & a 3ohm.svc off of a mtx te 801d
if you wire the 4 ohm sub voice coils in parallel you will have a 2 ohm load for the Image Dynamics sub, the JL sub only being single voice coil will of course be 3 ohm.
You cannot connect them both to the amp you specified as when connected the total load will be less than 2ohms and the amp will either trip it's protection circuit or could damage the amp, My suggestion is to try each sub separately and decide on the one you like the most or obtain a matching pair for the 4ohm DVC.
Mar 05, 2012 | Car Audio & Video
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
How do you run bridged into 2 ohms dynamic power
If your amp can drive a 2 ohm load then you need to configure your speakers for such a load
1 DVC 12 inch sub with 4 ohm coils wired in parallel would give you two ohm.
series impedance you add the impedance together
parallel it is this formula (Z1^-1+Z2^-1)^-1
the negative 1 exponent is just the inverse so Z1^-1 is just 1/Z1 Figure out your combination for your speaker setup.
Dec 26, 2009 | MTX Thunder 4-Channel Amplifier 6304 Car...
I have a brand new L7 is it blown?
check to make sure your box is securely sealed and that the box itself is not rattling. if not, most subs require a break in period where they can not be played full gain/full volume for the first 48 or so hours... did you break in your subs by paying it softly the first day and slowly turning your amps gain and receivers volume up the next couple of days. if not, it is likely blown
Oct 07, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I'am looking for some INFO.....about IMAGE DYNAMICS IDQ-62 MID RANGE DRIVER. That's all the INFO on the speakers...A WEBSITE would be helpfull or some assistance installing them...I'll leave my home...
Hello dankxs,
Your Image Dynamics speakers are pretty high quality stuff. When sold new, they probably had a manufacturers suggested retail in the $250 range. But they were usually sold with crossovers and possibly tweeters and most online retailers discounted them heavily.
Try contacting Image Dynamics at one of the listed email addresses or phone numbers and request a users manual.
Hope this helps.
May 06, 2009 | Car Audio & Video
Popping sound! please help - jl 500/1 and two jl w3v3 2ohm subs
no connection are good + to + -to - thats all that matters. either the speakers are blown or you need a stronger amp. since you already tried speakers probably need bigger amp. definitley not the box. no such thing as a break in period, are the subs 10 12 inch or what. you could try to bridge them too that means hook both up to the same +-terminals, 2 wires per screw. it usually isnt the way they hook them up, its the wires fuses etc that cause problems. what guage wires is the speaker wire, the power line etc. if you give me these guages i might be able to get somewere
Feb 24, 2009 | Jl Audio 12W3 Car Subwoofer
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Amp overheating
wire size depends on source, not load capability. your amp can provide 500 watts, so gage should be about 8, provided your speakers are 2 ohms each... you can measure them with ohmmeter. If you have 4 or 8 ohm speakers, you should get impedance matching transformers. Also, you should use a supply capacitor on power feed to amp of about 10 Farads...these are large and not cheap, but they provide "backup" power for heavy bass loads.
Jun 08, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Car speakers
I take it that you are running it off a factory head unit and your not getting enough drive on the new speakers. Are the new speakers a component splits? Does it come with a separate tweeters and crossover? If so... are the new speakers 4 Ohm Impedance? Coz the only thing i could think of is that these new speakers you have must have a higher impedance than that of the previous drivers. the higher the impedance the less sensitive. Your can try to match speakers impedance usually head unit is at 4 Ohm. Please let me know how you went. Cheers
Jun 02, 2007 | Image Dynamics NX30 Car Tweeter
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
