Question about Kenmore Washing Machines
110 24422300 filling with water and then nothing happens
I have the same problem. I also pushed the switch down with a pen and nothing happens. Does this mean the switch failed? I didn't see a respones for that question listed. I also tried pulling out the dail and turning it to make it drain and nothing works except the first setting that makes the water load into the machine.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
I have a kenmore series 70 washer, top loading. It filled up with water and then stopped. I have tried other cycles, but nothing happens. The water won't drain and there are no noises. Nothing happens no...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24712300
Also see the Whirlpool Service manual for top load, direct drive washers including test procedures and a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you manually move the timer to the spin cycle and it drains and spins, the motor and transmission are OK.
If it won't do anything after filling, the problem points to the timer or motor.
It is relatively easily repaired but you'll have to decide if the cost is worth the repair.
Personally, I tend to fix rather than replace so I'm probably not the one to ask.
Oct 31, 2009 | Kenmore 24712 Top Load Washer
I have a Kenmore top load washing machine model #110.24422300 that is only 4 years old, I have done 1 or 2 small or medium loads each week. My problem is that at the beginning once the water is filled it...
Very good chance that the lid switch has failed. This is the switch that is pushed down by the lid itself upon its closure. Try pushing the switch down manually with a pen, or something small and see if it works.
Mar 14, 2009 | Washing Machines
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Will not run or drain
My wash machine doesn't open from the front but I am having problems with it not draining
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills with water but wont start
probably the switch is broken push the switch down with a pen or something that gonna fit in if it start change the switch or bypass it by bypassing it it will run even if the cover open cheers
Jan 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
111 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
