Question about Garden
How do I fix/adjust the brakes on my 17hp Lawn General Lawn tractor
Help
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
bargainbin2
  • 123 Answers
SOURCE: yardman 17HP lawn tractor blowing fuse when key is
Any time a fuse blows there is a direct short to grown. Fuses only work in a hot wire. Some where there is a wire hot wire with a bare spot touching the frame or another ground wire. The seat could have a wire pinched, the motor may have melted a wire or something simple like that. Move all the wire around and see if they may be pinched or touching another wire or it any are melted together.
Posted on Aug 28, 2009
  • 95 Answers
SOURCE: my craftsman 17hp lawn tractor shutters bad when
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Posted on Mar 21, 2010
  • 18 Answers
SOURCE: Lawn tractor dies when the clutch/brake pedal is let out.
safety switch somewhere
Posted on Jun 06, 2010
  • 36 Answers
SOURCE: husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
Posted on Jun 07, 2010
Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
May 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Want to download manual for craftman 42' 17hp briggs&stratton motor
Hi My Craftsman will not ingage into gear . is the cklutch and transmission one unit . is this an easy fix. Jim
Jul 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My mower brakes do not work
The adjuster is on the right side just in front of the rear wheel. its the clutch rod / brake rod . you will see a spring on the shaft with two nuts one used to lock the adjustment. loosen the nuts and turn the nuts so the nuts go towards the back of the tractor. keep checking the peddle for brake .
Sep 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Jul 31, 2009 | Garden
How do I adjust the brakes on a Murray 17hp 42'' twin cylinder wide body?
find your brake disc on your trans axle
find the 1/2 or 9/16 nut on the outside of the brake disc and turn it clockwise1/8 turn and retry your brakes 1/8 turn. at a time until you achieve adequate breaking
do not overtighten that nut as if you do you will not be able to move your mower in neutral after you let out on the brake /clutch
Jun 09, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
