Question about ASUS Eee PC 1001P Netbook
Wont turn on or charge
How do i reset my Eee PC after the adapter has been replaced.. it wont turn on or charge?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
1.Remove battery and also disconnect the adaptor and press for 30 sec for cmos cell to clear.
2.Connect adaptor and press power on switch
3. if still there is no sign of display on screen then you need to visit nearest service centre.
Posted on Apr 02, 2014
  • 157 Answers
SOURCE: No power/charge
Check that the battery is properly installed. Check the AC Adapter for power. Otherwise take the machine back to the seller. It is still under warranty.
Posted on Feb 03, 2010
SOURCE: how do i reset a eee pc 901
To reset my 901 XP, I remove the battery as shown on page 3-3 of the instruction manual.
The reset button can now be accessed: it is a small shiny metal
plate, about 3mm by 15 mm located on the left of the battery compartment (closest to the LAN port).
Press the metal plate once with a ballpoint.
Posted on May 12, 2010
shashank rai
  • 60 Answers
SOURCE: when i plug the power adapter in the laptop wont
no, there is problem with ypur power adapter plug which links with your laptop .few days back i ws having the same problem
Posted on Jul 17, 2010
kaywon17930
  • 203 Answers
SOURCE: my asus eee pc charger
Good Day User,
1. I suggest to check your outlet if it has current. 2. If it is good, try to check your power cable connected to your charger using multi-tester. If it has voltage then your charger may has problem. 3. Consult your nearest technician.
Thank you!
Posted on Apr 17, 2011
SOURCE: Problem with ASUS Eee PC 900 PC Notebook I
this means that the inverter which is used to backlight the screen is not working. Check again all connections of the LCD. It is very common to brake the inverter cause it is very fragile. If checking the connections doesnt help i think you should try changing the inverter, it is low cost. Check e-bay for a converter.
Posted on Sep 18, 2011
Asus eee pc 1000ha wont take charge from adapter
try unplugging from the mains, remove the battery, hold the power button down for 30 seconds. plug the mains adapter in and try turning on. if it doesn't work then it's either the power socket or the mainboard.
if it does work, then try it again with the batter in. if it stops working then your battery's shot.
Apr 13, 2013 | ASUS Eee PC 1000HA Notebook
ASUS AC/DC adapter not working
Replace it, cheaper in the long run.
Mar 29, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
Feb 16, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My asus notebook won't charge i just bought last five days ago, and now it won't charge.. i tried to remove the battery and attach the adapter, but it still doesn't open..
if it wont charge it most likely has a bad battery...if you just bought it, I would suggest returning it for a replacement. Make the vendor or manufacturer make good on their product.
May 12, 2011 | ASUS Eee 4G Notebook
The notebook just stopped charging, it worked fine until then. Do you think it's the battery or the charger? And where can I get new ones?
your going to have to try a new battery first and if a new battery doesn't work then you know its a problem with either the dc jack or the motherboard.
Here is a place for the AC Adapter:
http://www.amazon.com/HQRP-Adapter-Subnotebook-Replacement-Mousepad/dp/B003C0W88W
Battery would be located here:
http://ifuncity.com/Products/2202_Laptop-Battery-For-ASUS-Eee-PC-AL22-703-900A-900HA-701SD.htm
May 07, 2010 | ASUS Eee PC 701SD 8G Notebook
No power/charge
Feb 03, 2010 | ASUS Eee PC 1000H Laptop
Wont turn on reset button?
Sounds like damage to the USB port. Did the phone ever charge?
Look into the USB port and check for bent connectors - you may be able to straighten them. To reset - unplug AC and battery and press and hold the power button for 6 secs.
Dec 09, 2008 | ASUS Eee 4G Notebook
Wont work
remove its battery insert it again, check whether the adapter is working or not
Oct 03, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 1001P Netbook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
