Question about Datamax DMX E4203 Printer
Vista for datatagger
How can i install the datatagger labeling system on my windows vista?
Black screen v6000 laptop "HELP Please"
It appears the hard disk has been wiped/formatted and does not have an operating system installed.
You need to get a Windows Vista installation CD and if the Windows label on the bottom of the laptop is still attached then this label has the product installation code.
Boot up with the Windows Vista installation CD to install the Vista operating software then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 19, 2012 | Compaq Computers & Internet
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Need activation key of vista(all)
You can't get a Windows Vista Key on forums like this you have to buy it directly from Microsoft getting a key in thru forums or even Ebay is Ilegal you can only get them at www.microsoft.com .
Mar 21, 2010 | HP Pavilion dv9000z Notebook
My computer window XP want window activate key
you have to look at the windows dvd front label or you can google for something like 'activation key for windows'. There are some common activation keys that worked for more than one installations
Jul 14, 2009 | Microsoft Windows Vista Ultimate Edition
Original windows
Have a look at the bottom of your laptop and you should see a Windows label which will have the Produce key printed on the label.
Borrow a Windows installation CD, must be the same as the Windows version that is printed on the label eg. Windows XP Home, or Windows XP Professional or one of the Windows Vista versions.
Use this CD to reinstall Windows on your laptop.
If you haven't got a Windows label, you need to purchase a new Windows install CD or if you have a old version of Windows 98 or ME to can purchase a Windows Vista upgrade which is much cheaper than buying a new Windows Vista.
Jun 23, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
I got Label Factory Deluxe a couple years ago, I now have a new computer with Windows Vista, I'm wondering if Vista supports my Label Factory Deluxe?
here is a link to an update that add's vista compatibility to the product Label factory 3 delux.
It's towards the bottom of the page. Without this update the documents indicate that the software will not work.
Nov 26, 2008 | Microsoft Windows Vista Home Premium with...
Windows XP drivers for joybook R43
Some computers are labelled "Designed for Vista".
This means that the manufacturer of the computer
will *NOT* be creating device-drivers for Windows XP.
Re-install Vista.
Sep 28, 2008 | Computers & Internet
Memorex Expressit S.E. 2.2 software for cd/dvd labeling
I installed it on Vista Home Premium and it works for me !
May 18, 2008 | Microsoft Windows Vista Ultimate Edition
Datamax DMX E4203 Printer Logo
204 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
