Question about Toshiba TDP MT5 original lamp
Reset lamp timer
Replaced lamp but did not reset timer now lamp will not turn on and it will not reset timer
  • Toshiba Master
  • 3,874 Answers
Make sure the bulb is pushed all the way in place and then when the door is fitted back on check that the switch is pushed in by the door catch.
Posted on Apr 04, 2014
How to reset the lamp timer for Sony Projector vpl-px32
    Instructions
      • 1 Turn on your Sony projector after replacing the lamp.
      • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
    • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
Jul 07, 2014 | Panasonic PT-44LCX65 Television
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
    1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
    on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
    2. Press the MENU button on the remote controller, or the RESET button on the control panel,
    while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
    appear.
    3. Press the and select 0, and wait until the timer display is cleared.
    Feb 18, 2011 | Hitachi CP-X270 Multimedia Projector
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
    Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
    Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
    PT-61DLX75 replace lamp light reset
    To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
    Sep 20, 2009 | Panasonic PT-61DLX75 61" HDTV
    Can't reset lamp timer
    Turn on the projector, and reset the lamp timer.
    (1) While the projector running, press the MENU button to open the menu.
    (2) Choose the “OPTION” on the menu using the / button, then press the
    button or ENTER button.
    (3) Choose the “LAMP TIME” using the / button, then press and hold the
    RESET button for 3 seconds.
    (4) Choose the “RESET” using the button.
    memo When the lamp has been replaced after
    Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
    Reset Timer Lamp Sony VPL-HS60 projector
    To reset the lamp timer:
    1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
    2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
    3) Timer should now read '0'.
    Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
    Toshiba TDP MT5 original lamp Logo
    175 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
