LG TROMM CE ERROR CODE - Washing Machines
  • 15,935 Answers
This is a *rare* error.
Overcurrent error. Caused by an obstruction in between tubs, too many clothes, too much detergent, wrong detergent.
Clean out soap dispenser, remove lodged items. Lessen clothing in tub make sure tub turns free.
It's highly unlikely the motor is at fault.
UNPLUG THE WASHER...
** Inspect all wiring connections at the MAIN BOARD (see below instructions).
** Inspect the wiring at the motor--remove the rear service access panel.
Remove the 17mm bolt at the center of the rotor--this can be tight as threadlocker is used.
Pull off the round shaped rotor. Use some care--this rotor has magnets lining the inside of it--it's not super fragile but can crack if hit sharply.
Inspect the two plug connections to the motor for loose or frayed wiring.
Also inspect the wiring which runs from the base (bottom) of the washer-to-the-motor.
Once or twice--I have found wiring frayed from the gyrating tub assembly (repair as needed).
If no obstruction such as a nail or similar object can be seen in the drum (small holes in tub)...
if the drum turns freely by hand...
the most likely fault will be the MAIN BOARD has failed.
This job is very simple:
Remove (3) screws at the top of the control panel.
Pull the control panel towards you & upward.
Remove the screws that attach the MAIN BOARD to the Display Board. Install new MAIN BOARD.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
rickzilla
  • 706 Answers
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Posted on Sep 20, 2008
MNTECH
  • 1543 Answers
SOURCE: LG tromm error code 0E
That's not OE, that's DE as in Drain Error. Open the access panel on the lower left front of the machine, use the small hose to drain out the remaining water, then unscrew the large plug and clean out the filter attached to the plug. If there is nothing in the filter, you may have a blocked pump impeller (not very likely as the filter stops most objects) or the pump impeller may have come off the pump motor shaft. If the later, replace the pump motor, as just popping the impeller back on will only result in repeat of your problem.
Posted on Oct 31, 2008
  • 8 Answers
SOURCE: LG TROMM CLOTHES WASHER - "LE" ERROR CODE
I tried a solution I found elsewhere - worked great. I had turned my drum enough to cause the display to turn on (a glitch in their program, I think), then I got the LE code on the next cycle.
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
Posted on Feb 28, 2009
SOURCE: LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Posted on May 16, 2009
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
How to fix an error code "CE" on my wm1812cw lg tromm front loader5
See if the top will lift up, if so there will be a code and test sheet in there that will lead you to fixing the problem. Very easy to follow.
Jan 06, 2016 | LG Washing Machines
What is BE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
you have a BE error thats not listed i think its something to do with the motor in the pump
i think it could be the pump
take it out and examine it for any sign of rust/ damage etc
this could be a crack in the housing inside the pump causing a leak not always leaking out just into the inside of the pump motor
although OE is drain error BE maybe pump motor error
as its closer to the CE and LE other motor errors
isolate the mains supply too the machine and wait a couple of mins and plug it back ?does the error clear
if it is there when you didnt select a cycle then its something thats detected pre runtime
Jan 03, 2015 | LG Washing Machines
What is CE error code on LG TROMM WM1814CW
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
Have an lg tromm washing machine wm1814cw, it has an error code of ce, what is that.
'ce' stands for Current Error i.e. the motor (or something else) taking too much current to run requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 08, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Lg troom ce code?
This is a communication error failure code. Something like this will have to be diagnosed with a meter. Several checks will need to be made to find the root cause of the problem. Please see the image attached for more info.
Jan 20, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
On my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Nov 28, 2009 | LG WM1814CW Front Load Washer
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,270 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
