Question about Saeco Odea Go
Insert coffee brew group
Insert after cleaning brew group
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 48 Answers
Odea go
insert coffee brew group - 91c38279-1a57-4666-be2a-b370865c3b5d.jpg 79bf0aa9-9c7b-4de8-b9df-ac131b23c319.jpg
Posted on May 05, 2014
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
  • 55 Answers
SOURCE: Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Posted on Dec 18, 2009
  • 1089 Answers
SOURCE: Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Posted on Jan 10, 2010
espressonist
  • 1711 Answers
SOURCE: Saeco Magic Comfort Plus dumps
From your description we understand that your machines vital parts like water pump, grinder, group and gears, boiler, electronic board all are working fine since there is a final result the coffee.
The only problem you face is that due to long time use some coffee liquid have dry out layer by layer and have goggle the Teflon pipe of the plastic unions so the coffee cannot be deliver through to the coffee tap and as a result is ending in the coffee drugs drawer.
So you need to disassemble you machine and remove the Teflon pipe which is after the coffee croup and by using a thing metal wire like a paper clip or similar you can check the pipe and the plastic unions to find out where they are goggled from dry coffee. You can immerse them in boiling water from some minute so the dry coffee to dissolve and be removed completely. By this chance you can remove also the coffee group filters and also clean them with hot water.
We have here below the link with exploded parts view of your model which will help you find the parts and understand how your machine is constructed.
http://www.partsguru.com/user/E003039-ed1.pdf
Also you may now you don't have any problem but we suggest performing at least once every month de-scale so to keep your machine in perfect condition.
Also if you might need nay part replacement you can even order it from the same side in this link
Posted on Dec 11, 2010
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
My Saeco incanto sirius coffee machine started the day with brew group blocked error. I have fiddled and got as far as it grinding beans before saying brew group blocked again. I took it out and now it...
If it stopped working after that incident of reset, could be. Water could have also gotten in the controls. I would use an air compressor and clean out all the alignment areas and switches.
Nov 02, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
The brew group to my Vienna Deluxe is out of sync. I cannot get it to fit into the machine and then add the dump box for the grains. They do not fit. I do not want to force the brew group into place....
Problem: Brew group is out of sync. Brew group insertion. Brew group alignment.
Answer: Common to all Saeco superautomatics. After removing and cleaning the brew group, it will get onto the supports but will not lock into place as the gear is not aligned. With the brew group on a clean, well lit table, use a pair of chopsticks and a friend to assist. There is a small lever arm on each side that is accessible from the outside of the brew group. As the carriage slides down towards the correct position, the arms are seen 1" above the drive gear and towards the handle side of the brew group. Gently push in the lever so it slides inside of the locking bar. Both sides need to get pushed in at the same time so it helps to have a friend hold the brew group and push in one side while you pull down on the carriage and push in the other lever. The chopsticks insert into the half-moon on each side above the locking mechanism.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna gear jammed
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Nov 07, 2007 | Saeco Vienna SuperAutomatica Coffee...
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
73 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
