Question about Kenwood KDC-MP2035 CD Player
It won't power on, the security light works when face plate is off
You can put cd's in and take them out
  • 2 more comments
  • Mary Yount
    Mary Yount Mar 30, 2014
    we had to change the heater core,and we unplugged all wires and when we put it back in i can't get anything to work
  • estoman711
    estoman711 Apr 28, 2014
    Sounds like a loose acc wire
  • Cosmin Verde
    Cosmin Verde Jul 22, 2014
    Hello Mary, have you solved your problem ? I`ve got the same today and didn`t found the solution. Can you help me ?
  • Cosmin Verde
    Hello Mary. I`ve got today the same problem, can u help me ?
  • 4 Answers
HI.. YOU MAY HAVE LEFT ONE OF THE POWER WIER UNPOWERD THESE STERIOS HAVE TWO .
Posted on Mar 30, 2014
5 Suggested Answers
ttech
  • 139 Answers
SOURCE: No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Posted on Jul 20, 2007
robotek
  • 1512 Answers
SOURCE: display
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Posted on Dec 28, 2007
tech48
  • 624 Answers
SOURCE: power to stereo none to unit
There is a ribbon cable that goes from the display to the main board of the radio that may be bad, if you have everything connected properly and all you get is the red led, this is a possibility. No way for anybody to know if you have it wired wrong if they can not look at it themself.
The red wire is for power when the key is on, the yellow wire should get power all the time, the black wire is ground.
If you have those correct, the radio should at least turn on. If you have these right, you may need a new ribbon cable. The connector that interfaces with the detachable face must also be taken off the old ribbon cable and put on the new one, or get a new connector and just replace it. The ribbon cable does not come with that connector. It is soldered on the ribbon cable, so if you are not very good with a soldering iron, you should have a service center do it for you.
Let me know if you want the part number for the ribbon cable and/or connector, I can get those for you.
I can not guarantee that the ribbon cable is the problem, or that it is the only problem, but it is the most likely problem with that model number of Kenwood. I have repaired many of them, so I have a good idea what causes most of the problems, but I have seen times when the usual suspect is not the problem and something else like the LCD in the face is bad, or the IC that controls the display is bad. Even a voltage regulator on the main board of the radio can be at fault as well. There are probably about 10 different things that can cause that one problem, having an experienced technician is always the best way to determan the problem with certainty.
Let me know if I can be any more help for you.
Dave
Posted on Jul 25, 2008
  • 233 Answers
SOURCE: face plate wont turn on
On the faceplate back, there should be some metal contacts. Take a white (not pink, red, purple, etc) pencil eraser and clean the contacts on the faceplate back. You can take a little rubbing alcohol and a q-tip to the contacts on the player itself...just use a little bit. Let it dry for about 5 minutes and try again. If it has a reset button, you may try pushing it, however that will most likely reset the clock, radio stations, and any eq settings.
Posted on May 30, 2009
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
I provided 12v from car the security red light blinks, but when I attach face plate the stereo is dead?
do you have power going to both the yellow and red wires????????
yellow is constant power and red is switched power (ignition).
May 31, 2010 | Audiovox ACD-22 CD Player
Control head will not power up. I put power to the unit and hear the cd player movement working inside but no control head activity
make sure the face plate is in correctly. This unit has a removable face plate and it could be half way in. Also, check to make sure the little copper contacts are clean.
Dec 02, 2009 | Kenwood KDC-2011S CD Player
Face plate wont turn on
May 30, 2009 | Kenwood KDC-MP628 CD Player
Face plate wont light up but power is getting to it
make sure face plate is firmly put in place with no obstructions hindering the circuits behind face plate
May 20, 2009 | Car Audio & Video
Daewoo Cd player
The car security is not connected to a head unit. It probably has a small blinking red light on it which blinks when you remove the faceplate and switch the ignition off. This is just an indicator which lets people see that the face plate is removed.
You can replace the headunit with any brand/model you want. It would be cheaper than buying a replacement faceplate.
Aug 03, 2008 | JVC KD-S5050 CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Jul 20, 2007 | Kenwood KDC-2019V CD Player
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Kenwood KDC-MP2035 CD Player Logo
88 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
