Question about Mitsubishi WD-60638 DLP TV
Mitsubishi WD-60638 firmware
Try to update my Mitsubishi WD-60638 DLP TV firmware. Followed the instructions. It stay at the welcome screen for an hour. Try to restart the firmware update by turning it off. Now its stuck at the welcome screen now. Wont get pass that. I've try to redue the firmware update over and over but nothing. Update: I just released that the usb port isnt getting any power. Normally when I plug my usb into a port, it lights up but with the tv's port, it doesnt light up. Plugged in my Ipod (because if its plugged into a usb port, the screen turns on)into the tv usb port but nothing. This tells me no powers getting to the port. I just want to know what part do I need to replace in order for it to work. The Formatter Board or the main board?
  • Jesse Hernandez
    Jesse Hernandez Mar 30, 2014
    I think my best line of attack would be to replace the main board. Formatter Board wont do much good without input\outputs from the main board.
  • Jesse Hernandez
    Jesse Hernandez Aug 02, 2015
    Had the same issue with my Mitsubishi WD-65638. Did an update and ever since then it just gets stuck at the blue screen. I know its the board because when I use to plug my usb into one of the usb slots in the back, the usb be would light up. Now it doesn't light up at all which tells me no powers running through the board. I also tried this with my Mini Ipod (which lights up when plugin into a usb slot)
    Sergeant:
  • 418 Answers
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Posted on May 09, 2014
patopato
  • 3 Answers
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Posted on May 07, 2008
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
SOURCE: Wd-73C9 Power on TV and gets stuck on Welcome
My WD-65C9 is doing the same thing. I got the update and it did not work. Only make sense, why would an upgadre fix a problem, it would give you more features or fix color problem that have always been there, but to fix a lockup. I think it is the mainboard from what I have read on the net.
Posted on Dec 15, 2010
Testimonial: "thanks for the feedback :) "
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Posted on Oct 05, 2011
i did the manual switch on the orange power wire on the fmt module,it still works so far... thanks
Posted on Feb 02, 2012
My WD60638 has a couple of white dots on the screen, what causes this and how can i fix the problem
if its a dlp tv most likely the dots are from.the bulb if its an lcd tv your screen may not be of high quality u need to change it
Oct 02, 2015 | Mitsubishi WD-60638 DLP TV
I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
WD-60638 COLOR WHEEL PROBLEMS
Usually the wheel is not available except with a Light engine.
Aug 31, 2012 | Mitsubishi WD-60638 DLP TV
HOW TO HOOK MY LAPTOP TO MY WD-60638
The easiest way would be through a HDMI cable.
Jun 15, 2012 | Mitsubishi WD-60638 3D-Ready DLP HDTV
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
May 23, 2012 | Mitsubishi WD-60638 DLP TV
Green status light stays blinking on the welcome screen
You need to go to mitsu's website and download the newest firmware update. It will come with instructions on how to install. This will fix your problem.
Mar 17, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi wd 65737, tv gets to the welcome screen then turns off. What is the problem?
Try unplugging the power cord for 60 seconds and plugging it back in. We had the same problem and that worked the first time we tried it. The problem is back and, after some frustration, the manufacturer recommend updating the software. Contact your local Mitsubishi service rep. to obtain updated software and instructions. Good luck!
Dec 02, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-60638 DLP TV Logo
362 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
