Question about Hobart H600 Stand Mixer
Looking for a replacement part # P-61506 sleeve-square drive
Drive needs to be replaced
I can't get the mixer parts in the hole to fit in. The model no is k5ss.i want to use my roller to make pasta dough?
Sometimes the square shaft of the attachment does not quite line up with the square hole in in the drive of the mixer. Take a look in the mixer's attachment port and turn the attachment's shaft so that the two line up.
Dec 17, 2017 | Food Mixers
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
In the middle of making my cookies the mixer turned off and wont come on again
Make sure it's unplugged, remove and inspect the carbon brushes one at a time under those black screws on the side. They are keyed with one corner of the square ground off so will only go in properly one way so eyes open when you take them out. If they are less than 10mm long replace them. Next would be look under the back cover for a broken wire to the black square speed control plate. Broken wires are only likely to be one of the bottom 2 on either side. Any more testing is going to require a multimeter.
Dec 20, 2015 | KitchenAid KSM150PS Artisan Series Stand...
My artesian kitchenAid stand mixer will not turn back on after using it
After many years of use, the mixer is running slow and having trouble mixing cookie dough. There's even a slight burnt smell and a little smoke coming from the unit.
I have repaired my same mixer a few times, first was replacing the plastic gear that is fairly common. Next I replaced the bearing and then the motor eventually, recently I replaced the main board. All these parts are fairly cheap and easy to replace. I have never had one smoke however so it is possible a wire could have rubbed enough to be shorting. Take the back cover off and inspect, its just the one screw on top and the main board is in there and see if any wires look shorted.
Jun 30, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I have a 7 cup food processor (model #KFP07110B) and the multipurpose blade has recently started to slide up/off the mixing bowl as it's running. Is there a way to fix this? Would purchasing a new blade...
Owner's manual troubleshooting? No manual, try MFG customer website or phone. They may like to know you are having problems. They may know this is a problem and may send you a replacement free.
Mar 26, 2015 | KitchenAid Food Mixers
My kitchenaid artisan mixer doesnt run fast enough
It may be seizing up the bush that your accessory drive runs in, if you can see grindings in the front by the square drive that is a sign. Here in NZ that bush is only available as part of that whole top cover/housing. The accessory drive gear will also need to be replaced.
Feb 17, 2014 | KitchenAid KSM150PS Artisan Series Stand...
How do I replace the brushes on a Kitchen Aid k5ss mixer. I took the black plastic buttons and the spring out but the brushes seem to be stuck. One of the had pieces of what I think is carbon off the...
I normally CAREFULLY drill a small hole thru the centre of the brush and get it out with a hooked probe. The brass square sleeve that the brush goes into can slide out with the brush. Make sure that doesn't happen because if it does you'll be splitting the cases to get the brush holder wire back where it belongs.
Feb 14, 2018 | KitchenAid K5SS Heavy Duty Commercial...
Springs on side under black screw, came out
Or, more helpfully, take them back out.  Look in the hole, and you will notice that when you look through, the hole turns square. At the end the square, there is a little tab / square in one corner.  It is generally *not* the same on both sides. You'll notice that the end of the piece you took out (the part that looks like a magnet) has one corner cut off -- so it's a rectangular box with one of the corners gone.  Line up the missing corner of the piece you took out with the corner that has the little tab -- this allows the piece to get past the tab and be fully inserted.  Reminder: check both sides, because they're not the same. And now, more helpfully, if you're curious, check out flea markets and get a broken Kitchenaid to take apart for $20 or so. Don't mess with your nice one. : )
Apr 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart H600 Stand Mixer Logo
60 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
