Question about Honeywell HE365 Humidifier
Furnace off and water still dripping. should I go to lowes and get hose are change filter and turn back on and see if it stops
Filter was dirty and I replaced it can I turn it on and just find a new hose
3 Suggested Answers
  • 21 Answers
SOURCE: Water flow from humidifier never stops. Even when furnace is off.
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Posted on Aug 20, 2009
HVACjake
  • 22 Answers
SOURCE: Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Posted on Jan 21, 2010
Honeywell he240 no longer working. It is less than 2 months old. I noticed water had stopped flowing out of drain tube. The filter tray is not filling up with water. Humidistat clicks when turned up and...
Maybe the hose is blocked. Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Try this site for more details or a similar issue:
Honeywell HE240 new install not working
Feb 12, 2015 | Honeywell Humidifiers
Is Aprilaire 500M suppose to turn on when furnace motor turns on?
The humidifier should turn on and off with the blower motor of the Furnace. This can be done by wiring the the humidifier to the HUM terminal on the furnace control board and then stepping down the power with a transformer. If the humidifier has it's own tarnsformer then a current sensing relay can be used by attaching it to the blower motors common wire.
Jan 13, 2013 | Aprilaire Humidifiers
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
Water doesn't shut off completely (drips) when furnace is OFF. Water doesn't increase to a stream when furnace is ON. Also, black connection (regulator ?) between copper water pipe (inlet) and black...
Hi i would check you water line see if they are blocked and checkout the valve and the jet inside where the water goes donw the pad they could be blocked
Feb 11, 2010 | Aprilaire 550 Humidifier
Why won't the water stop running?
When my humidifier refuses to turn off, it is always because the plunger in the electronic valve is stuck.
When the rheostat senses low humidity, it sends current to a coil, this creates a magnetic field that pulls a plunger up into a tube away from a rubber gasket (hole in center to match plunger) and water flows thru the hole. When humidity is high, the rheostat stops the current, and a spring/gravity push the plunger back against the gasket.
The plunger or the tube can get deposits, or just rust ever so slightly, and then the plunger gets stuck in the up = on position.
Buy a new solenoid valve $$$, or take your solenoid apart and clean the plunger and the tube with steel wool.
Jan 09, 2010 | Aprilaire 600 Humidifier
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Apr 17, 2009 | Honeywell HE365 Humidifier
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
Honeywell HE365 Humidifier Logo
49 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
