Question about Angelo Brothers Westinghouse (r) Savona ES Ceiling Fan (72087)
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
The alarm on my virtuoso westinghouse fridge at the bottom and freezer at the top continues to go off. I don't know how to stop the annoying beeping as i turn it off it goes off again after a short period of time. The freezer is not working- food is not freezing and the fridge is not cool. Milk and other products are going off. NOT GOOD ENOUGH!!! You buy a fancy refrigerator with a stupid alarm that doesn't even need to be there and it completely stuffs up the cooling. What can I do so that I can solve this issue and provide healthy safe food for my two growing boys.
    Problem Solver:
  • 9 Answers
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Posted on Apr 26, 2017
Westinghouse fridge freezer keeps alarming. Help
It is possible that there are more things wrong but my fridge freezer did that and I had to refill it with Freon gas. You need to get someone who knows what they are doing.
Jun 21, 2017 | Westinghouse Refrigerators
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
I have a westinghouse virtuoso fridge/freezer. The freezer alarm goes off every 1/2 hour and the freezer is cool inside it does not seem to be maintaining freezing temps. Is there anything i should try?
i have this fidge and suffer the same problem, i rang the company and it was only when i spoke to the manager he mentioned quietly to turn the fridge of for 5days with doors open to completely dry out the inside as its water gathering inside at the back and it worked the alarm stoppped, it was only cos i mentioned i couldnt afford hundres of $ for a repair guy, share the news it sounds commen in the model, ggod luck
Dec 17, 2010 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse virtuoso fridge/freezer has stopped cooling. How do we check the fuses etc? seals on the doors are all fine.
I have the same fridge (stainless steel virtuoso) and when the fridge section stops cooling you have to turn power off. Then remove everything from the freezer including the shelf. Next get a pointy object and remove the two plastic screw covers located on the back inside plastic freezer panel, Next remove the two phillips head screws securing the panel in place. Next (and this is a little tricky) get two solid forks and lever the back interior panel off, thereby exposing the cooling system of the fridge. Next get a hairdryer and completely defrost this item, and then reassemble. Switch power back on and your fridge will be fixed, and cooling like a champion! plus you have saved hundreds by not paying ripoff "technicians" I have to do this every six or seven weeks because of the high humidity here in Darwin, the freezer is "frost free" but the cooling system still ices up, and this is what blocks airflow and stops the fridge cooling.
Aug 03, 2008 | Refrigerators
Angelo Brothers Westinghouse (r) Savona ES Ceiling Fan (72087) Logo
150 people viewed this question
Top Angelo Brothers Dryers Experts
Are you an Angelo Brothers Dryer Expert? Answer questions, earn points and help others
