Question about Compaq Presario SR5710Y PC Desktop
Replacement for Compaq SR5710Y CPU cooling fan and plastic screw motherboard mount?
I have a Compaq SR5710Y tower that has a broken plastic mount (screwed onto the motherboard). I need to replace both the cooling fan AND this plastic base. Not able to find a site or a model that would be physically compatible online. Anyone have any suggestions? Thanks.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 96 Answers
Posted on Mar 31, 2014
  • 12 Answers
SOURCE: replacement for the spring loaded door on my tower
No solution for this. All cd players are non repairable or at least not cost effective to repair. My advice is to just purchase another one. Cost for these is now in the $40.00 range - cheaper then getting this one fixed
Posted on Dec 30, 2008
  • 63 Answers
SOURCE: How to get back off the Compaq Presario sr5000?
Its not the back that you will get open it is the side pannel that slides backwards
Let me know... Matt
Posted on Jan 25, 2009
jell587
  • 447 Answers
SOURCE: Motherboard crashed in My HP Compaq Presario S6500NX
According to these specs it should be an Asus A7V8X-LA. This link will show you a list of these boards available on ebay.
Posted on Feb 23, 2009
philmik
  • 107 Answers
SOURCE: sir when i purchased my desktop then the
Here are your Compaq Drivers just choose OS you need. Good Luck!
Posted on Apr 23, 2009
clb199
  • 164 Answers
SOURCE: compaq presario s3010cl motherboard replacement
Just about any Socket A / 462 Motherboard in the mATX form factor will work. make sure your memory and CPU are compatible with the motherboard before you buy.
Posted on Nov 24, 2009
Testimonial: "Thank you for your quick response! :-)"
I can't get my CPU fan to connect to my mother board because the plastic clips are broken what can a do
What is the make and model of the motherboard and what is the make and model of the fan?
Mar 29, 2013 | Computers & Internet
My Acer Aspire M5100 get power but will not turn on
Does the CPU fan come on ?
Does the power lead that plugs into the cpu fan on the motherboard supply the required voltage ?
This one is a bit harder and once you check it you most likely need to apply thermal paste - but is there sufficient thermal paste between the CPU and the heat sink on the CPU ?
Does the power supply box in the tower case have its fan spinning when power on ?
Is the motherboard bent ?
I have seen this one - poor installation with different sized mounting screws. When motherboard gets hot the motherboard went faulty.
Some motherboards need a rubber insulator under the screw maybe there is a short under one of the mounting screws !
Mar 12, 2017 | Acer Aspire M5100 AM5100-U5313A AMD...
Which way does the rear fan go in a compaq computer tower
The proper installation of a CPU fan is often the subject of debate. Though there are conflicting theories as to which direction the CPU fan should face, there are methods to ascertain which CPU fan installation best suits your needs. The determining factors of your CPU fan installation direction include the manufacturer specifications, your case design and the specific design of your heat sink
Horizontal Installation
  • The installation of a CPU fan horizontally to the plane of the motherboard is the most common installation orientation there is. Your options when installing your CPU fan are to blow cool air onto the heat sink or to pull cool air through the heat sink from the motherboard. Horizontal installations show negligible advantages in either installation direction. The differences in temperature usually vary by only 1 or 2 degrees Celsius. The main point to consider when installing a horizontal CPU fan is the location of the rear exhaust fan on the case. If the rear exhaust fan on the case is parallel to the processor, it is advantageous to have the fan pull cool air from the motherboard and push it out above the heat sink. This is because the case fan will quickly draw that hot air away from the CPU and out of the case, allowing for quick cooling.
Vertical Installation
  • Vertical, or tower, heat sinks rise high enough off the motherboard to allow for a fan to be installed perpendicular to the plane of the motherboard. This allows for cooling to go from the front to the back of the case, as opposed to going from the bottom to the top. Optimal installations for vertical heat sinks are blowing toward either the back or the top of the case. If there is no exhaust fan in the top face of your computer's case, it is more effective to orient your fan on your vertical heat sink so that it blows toward the rear exhaust fan of the case. If there is an exhaust fan on the top face of your computer case, it is almost always more effective to mount your CPU fan so that it blows air up toward the top of your case. The reasoning behind this is that hot air rises and will more naturally flow off the top of your case. Also, top-mounted fans are usually larger and allow for faster airflow out of the case.
Manufacturer Recommendations
  • It is often the case with nonstock heat sinks that the manufacturer has designed the heat sink's fan to be mounted in a limited number of orientations. This is usually evidenced by limited mounting notches on the heat sink itself. Most aftermarket heat sinks use technologies such as heat pipes that have specific cooling needs to operate appropriately. Because of this, it is important that in any CPU fan installation you follow the manufacturer's installation instructions.
Performance chips of BMW
May 31, 2012 | Compaq Hp - 375376-001 - Dc7600 Tower...
I have a vostro 200 large tower with a g33m02 motherboard. The cpu cooling fan is very loud. (not bearing loud, but it seams to try a lot harder than it needs too for what the computer is doing.) the cpu...
Check your BIOS Settings
CPU Configuration
CPU Internal Thermal Control [Auto]
Hyper Threading Function [Enabled]
Intel(R) SpeedStep(tm) Tech [Auto]
Power>Hardware Monitor
CPU Q-Fan Control [Enable]
CPU Fan Ratio [Auto]
CPU Target Temperature [60degC] (lowest setting available)
or you can replace it with Cooler Master XDream
Sep 20, 2011 | Dell Vostro 200 Desktop Computer
Hi Compaq 323091001 Motherboard failed in my Compaq d330 desktop. What are some suitable replacement motherboards ? Tony
Hate to tell you, but I just searched on my usual sites and I couldn't find a motherboard that would work. Main concerns:
socket 478 (only found two boards with this) ddr memory (no boards with this) intel 865g chipset (again no boards with this)
Last but not least- most likely a non OEM motherboard is not going to fit inside the tower you currently own. Usually HP/Compaq/Dell use odd motherboard mounting screw locations so you cant just put any motherboard in.
You may be better off buying a new PC.
Mar 06, 2011 | Compaq (323091001) Motherboard
I have a compaq laptop and my cooling fan stopped workin how do i get to it?
You will have to open the case. This is normally done by removing the plastic strip above the keyboard, removing the keyboard, and then opening the case.
Most laptops have screws on the bottom of the case. In some models, the keyboard screws have a little picture of a keyboard next to them. Eventually, you will probably have to remove all the bottom screws. The keyboard will have screws at the top of it, so they are removed from the top as well as the bottom.
The case is held together with plastic tabs. Once all the screws are out, you can start in one corner and using a plastic or wooden flat utensil (actually a cuticle tool is good if it's plastic or wood) and gently pry the case apart. Then you can get to the fan. It's probably attached to a heat sink which cools the CPU, so you will need to use heat sink compound when putting it back together.
Feb 13, 2011 | Compaq (123482-001) Cooling Fan
How to replace motherboard
1. Contact eMachines, and purchase an identical replacement motherboard.
2. Disconnect all the exterior cables from your computer (keyboard, power, mouse, et cetera).
3. Remove the side-panels.
4. Disconnect all the interior cables from your motherboard (power, data, audio, et cetera).
5. Unscrew any screws holding add-in cards (modem, video) in-place.
6. Disconnect those add-in cards from the motherboard.
7. Unscrew the mounting-screws that hold the motherboard to the case.
8. Lift out the motherboard.
9. Take the RAM out of the old motherboard.
10. Take the heat-sink-CPU-fan and CPU off the old motherboard.
11. Put the CPU and RAM onto the new motherboard.
12. Reverse the above steps, to reassemble.
Jul 17, 2010 | E-Machines eMachines Desktop PC
I HAVE A COMPAQ PRESARIO SR1339UK, THE PLASTC
you can install an other cpu cooling.
You have to find out which socket the cpu got and the size .
it has to fits to your pc case.
Look for some videos on youtube .There are some good guidlines
for cooler installin.
A cpu cooler is not very expensive but most a time a lot better than the standart cooler.
Jun 02, 2010 | Compaq Presario Fan
A claim
I had the same problem on my v2000. apparently the fan shroud for the cpu cooling fan is made of plastic and can deform. In my case the deformation allowed the fans blades to strike the heatsink stalling the fan. This would lead to system overheat and shutdown. I disassembled the unit removed the fan shroud and installed .5mm O-rings onto the mounting screws moving the fan away from the heat sink and allowing normal operation. This repair is not for the faint of heart as these are tiny screws.
Feb 01, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario SR5710Y PC Desktop Logo
128 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
