Question about Sony KV-36XBR450 36" TV
Red Colour is faded....looks almost purple?
I have been using my TV for 6-7 years with a Bell Satellite ExpressVu system. The TV is ALWAYS on.....I just turn off the satellite receiver and the screen goes dark.
After many years, I now have a faded red colour, not a deep rich red....it's almost purple? or Crimson.
There is not a Red, Green, Blue separate colour adjustment....only the on-screen adjustments.....they don't seem to fix the problem.
I'm not sure what to do? The TV weighs 235 lbs so it's not easy to take to the shop for a test/assessment. Is there a test I can do? Some standard RBG signal to check the colours?
Thanks for any help
    Genius:
  • 1,139 Answers
This might be caused by the CRT or by the chroma circuitry. You will need a schematic diagram and a multimeter set to read voltage. The first thing would be to look at the voltages on the CRT socket. With the TV on and the back off, using the schematic measure the voltages on the CRT socket and see if they match the schematic, if they do not (and they wont) find out if the Red Cathode voltage is too high of to low. If too high the red video circuitry might be at fault if too low the CRT might have a Cathode to grid short. In either case power down the TV and with determine if the CRT is bad (using a CRT Tester / Rejuvenator) Run a series of test acording to the instructions of the CRT Tester. This will tell you if the CRT is bad and if it is bad what problem it actually has. Then you may or may not have to rejuvenate the CRT (follow the instruction on the Tester / Rejuvenator) to do this. If the CRT is not bad then you will have to test the chroma video circuitry to see which component is causing the problem.
As you see you will need some equipment to do the job with. and you will have to have a little bit of an electronics background, If you do not have these I would suggest that you take the TV to a qualified TV repair shop for servicing.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 31, 2007
Haier tv I am hooked into Bell Expressvu. HD receiver and I can't get the picture to expand to the entire tv screen. i can only find HD Normal and it stays in a small screen view.
It might be necessary to change the resolution/Aspect Ratio (Screen Size) settings on both your HD Receiver and your TV.
I don't have Bell Satellite but I do remember having the same issue setting up my friends HD TV and Bell Satellite TV Receiver.
Nov 25, 2013 | Haier HL32D2 32 in LCD TV
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 23, 2010 | DISH Network IR Remote Control
I need 3 digit code for my Prima tv to program bell express vu
Dec 16, 2009 | Prima C2012 TV
Getting VCR to record from Bell Express View
try this website
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.doc
keep scrolling down in the list until you find the vcr codes.
i found the 3 digit code for my sony VCR. it gave me several codes, but i finally found the one that worked with my bell expressvu.
good luck
Jan 29, 2009 | Televison & Video
Device Codes
UNIVERSAL REMOTE CONTROL CODE LIST We have compiled a list (below) of codes for Universal Remote Controls. .... EXPRESSVU 464. FUJITSU 760 860. GE 265 863. GENERAL INSTRUMENTS ...
dogbytecomputer.com/codes.htm - 34k - Cached - Similar pages see if you code is in here.like my dishnet.remote,some no namebrand tv's just can't be controlled by other remotes
Nov 14, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Toshiba DVD/VCR Recorder
The only thing you can do is to program the recorder to come on and record at a certain time and also program the event timer for the Bell Expressvu.
Mar 13, 2008 | Televison & Video
Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Feb 14, 2008 | DISH Network IR Remote Control
Code for satellite bell (expressview)
Jan 03, 2008 | Televison & Video
Bell Expressvu 2700 satellite receiver av inputs
had my 2700 reciver unpluged for awhile now can't my channels back can you give me any idea how to fix this
Jan 01, 2008 | Televison & Video
6419ctb how to use av inputs
i needs the codes for the tv please
Jan 01, 2008 | Sylvania 6419TC 19" TV
Sony KV-36XBR450 36" TV Logo
196 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
