I have an emachine T4697. Had to replace the motherboard, cpu, and hard drive. The installation disks (recovery) cds that came with the original computer won't install. Need help.
  • 93 Answers
The installation disk that comes with a computer isnt for installing your operating system. Its for re-installing your drivers and such. So if you have formatted your hard drive you will have to install with the actual disk. The only way a recovery really works good is if you have created a backup.
Posted on Jun 15, 2009
Cav i use e recovery outside windows to restore lost or corrupt sys32 driver files on my E4024 emachine p.c.?
If your recovery partition is intact, or made recovery CDs, then yes. The machine will be returned the state it was in when it left the factory. If you have a pre-owned computer, or else the computer was not originally purchased with Windows pre-installed, the recovery partition may have been damaged or destroyed in which case the procedure will be very much more complicated and difficult and perhaps expensive..
Be sure you have copied your data to another disk and have noted any downloads yo have made so that you can replicate what you want.
You might take this opportunity to test your hard drive for faukts.
18.December.2014
Acer will have the procedure on their website, and here is another version:
http://www.ehow.com/how_2337743_do-emachines-system-recovery-.html
Jun 07, 2014 | eMachines ET1810-01 PC Desktop
Factory restore
If your particular eMachines model didn't come with recovery media or you just misplaced the disc, you don't want to be caught without a means to restore the operating system.
It's all too easy to accidentally download a virus or experience any number of problems that make your computer unstable.
However, there is an option for restoring your computer without the original recovery disc by using the pre-installed recovery software.
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your internet settings.
hope this helps
Sep 21, 2012 | eMachines T2862 Desktop PC 2.66 GHz...
I want to do a system recovery on my emachines but I dont have the recovery disk, can anyone email it to me?
nope recovery disks are either made specific to your computer or come from vendors otherwise they don't work too well
May 28, 2012 | E-Machines eMachines Desktop PC
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I built a computer for my aunt using an Intel motherboard, Intel processor, 2 x 500MByte DDR3 RAM in a Blue Ninja case purchased from Tiger Direct. The computer worked well for more than two years then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 16, 2011 | RaidMax Ninja Case (RDMXNJACAS)
Can not get pass set up, place where you name the computer,have run restore cd
Hello there , let put things in order:
1) That is is your PC DISC? RESTORE CD?
2) If so, just run the Restore CDs, and use DESTRUCTIVE FORMAT/ and restore the OS from CDs and SYSTEM PARTITION. **
it is supose to work.
other than this, may be a defective hard disk, use warranty, or have to replace that hard drive. ** be sure you got a full recovery CDS.
GOOD LUCK
Oct 16, 2009 | E-Machines eMachines Desktop PC
After emachine recovery disk run on new hard drive
that shows that it is not compatable with the settings of the PC.
Oct 06, 2009 | eMachines T6426 PC Desktop
Boot manager missing
The hard drive needs to be low level formatted, fdisk'd and FAT32 formatted prior to ME install. I don't know where to get free copies, but I've used both On Track's drive manager and Acronis v10. Bothe are very good your purposes. Both retail +- $50.00
Mar 23, 2009 | E-Machines eMachines Desktop PC
Upgrade to a new motherboard?
I think there may be another issue.. It could be the power supply.. Have you tried a new one?
Have you installed any additional ram lately?
You can use the old XP software with a new motherboard, but it can be a pain in the **** to set-up if it is the OEM version of Windows, or a Recovery Disk that came with your machine..
What you could do, if you bought another motherboard, find someone with a Genuine Windows XP disk, and use your Product Key to install it..
Apr 12, 2008 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
