How do I show me jerking off on line?
Just show my stuff on line
  • 3,320 Answers
Who wants to see that?
Posted on Mar 31, 2014
2002 dodge caravan jerks on reverse an drive..gave a tuneup..new gas filter//cleaned the throttle body//I don't know what's wrong on it..help
jerking can be a number of things, as you say you have cleaned the throttle body new filter for the fuel, when cleaning its best to change the air filter or at least checking it to make sure its clean and not blocked up. you can also sometime inadvertently dislodge something in the fuel line and this can limit the fuel, but i would thing it would show more signs, it could need the spark plugs cleaning, it could be a build up of carbon on the plugs and now the system is cleaner the mix is not igniting good, so i would check and clean them, lower rev's need a better spark. i would also check the breather lines from the cam to the intake especially the thine one as this can block up and limit the airflow into the engine. so really its just clean these parts and see if there is any change.
Aug 06, 2017 | Dodge Cars & Trucks
My Chery tiggo 1.6tx 2010 model is jerking while I driving
It depends on how violent the jerking is? Could be as simple as a plug &/or lead breaking down or as complicated as a fuel delivery problem. Sorry not much help, but I don't have much to go on..
Dec 16, 2016 | Cars & Trucks
97 tahoe 5.7 350 chugging, jerking, reving rpms intermittant
The first thing that needs to be done here is to have the engine control module scanned for fault codes, based on the results then move on.
Jul 16, 2017 | 1997 Chevrolet Tahoe
How will i know that my wife is chatting secretly with others in facebook or yahoo messenger?
You could put key stroke program on the computer. It records all keys that where hit when someone is using computer.
And don't be one of those jerks that are out doing all types of wrong stuff then get all mad and bent out of shape when your girl starts doing the same stuff.
Jun 21, 2011 | Computers & Internet
2002 Montero Sport 4X2 jerks during and after shifting into 3rd or fourth gear. Particularly bad going uphill. Not so bad during hard acceleration. Have changed fuel filter, plugs, etc. Even changed center...
Check the 'U' joints in the drive line. Check the engine/transmission mounts for damage or looseness. The real enigma is trying to determine if this is an engine or a chassis problem. If the check engine light is on, doing a scan of the computer should show engine problems. If no light, concentrate on anything in the chassis for periodic binding. Good luck!
Mar 15, 2010 | 2002 Mitsubishi Montero Sport
Ml320 keeps jerking while driving and the revs keep going up n down . how do i go about checking the transmission fluid and change it! the ignition coils n stuff are all ok
hello,checking of your oil level is not possible,only your dealer have the special tool to check the level,now you stated,jerking while driving,have many possible causes like fuel filter dirty or with water,sometimes spare plug, air filter,hoping your trans. is 722.6(5 speed) your trans. oil is 7.5 liters,but you have to check your oil level with your dealer.ty
Apr 26, 2009 | 2007 Mercedes-Benz ML320 CDI
Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 06, 2009 | Washing Machines
1991 jeep cherokee jerks while in 4x4 on turns..
The part time switch in the gearbox is sticking in the on position locking the 4x4 on. It feels and looks really bad because the front wheels are trying to pull the car left or right, while the rear axle is pushing you forward. This is at it's worst when in full lock on road or hard surfaces. This is why 4x4 is for off road only.
Feb 16, 2009 | 1991 Jeep Cherokee Limited
Mazda protege 94, jerks sometimes, and vibrates when full stop
it sounds like it may be out of time and in the case you need to replace timing belt and pulleys and get retimed
Feb 04, 2009 | 1994 Mazda Protege
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
