Question about Starfrit 93209 Rotato Express Electric Peeler
I need a new arm to attach the blade to
The part that holds the red blade has a broken part so the blade pops off in the middle of peeling
Phone les promotions atlantiques inc.
514-871-1671
product/ lameoo-641-0000
Description: lame pour 93169 potato
package of six replacements,$6.99(approx.) in Canada
Posted on Apr 01, 2014
2014 Honda CRV, drivers side wiper doesn't maintain contact with the windshield. New blades didn't help.
Sounds like the wiper arms are bent or the attachment clip may be broken, especially if new blades didn't help. If you stop by any auto parts store that installs blades, usually no charge, ask them to inspect your blades and see if they can offer a more specific solution. Otherwise, a visit to a mechanic is probably in your furure
Apr 05, 2017 | 2014 Honda CR-V
Wiper blade stands up in the middle. Push it down but it pops back up when you turn it on?
check and adjust the blade length. Ensure that in installing the new blades that you used the right sort as if the grooves in the blade or too tight on the arm clips this problem will result. The blade has to move freely in the arm clips
Dec 15, 2013 | Cars & Trucks
Replace rear wiper assembly
The wiper arm has a cover on the left end that pops up after gently spreading the two bottom sides apart. That allows the arm to swing out for cleaning the window or replacing the blade.
The wiper blade assembly attaches to the end of the arm . It is pressed in and will pop out with a little force rotating the left side away from the arm. It pops back in with a little push. The arm remains attached to the rotating shaft assembly.
I believe you can then replace just the rubber blade and not the whole blade assembly, if that is your fancy.
Dave
Oct 18, 2013 | 2008 Toyota Highlander
How do i take off the armrests from the bucket seats
  • On most vehicles the arm rest are attached the same way, here is something you can try...Put the armrest in the upright position. Look along the bottom and sides of the armrest where it connects to the body of the seat. There should be small circles like tabs if the armrest is made of plastic, and there should be a seam that you can look through if the arms are made of cloth.
  • Pop out the tab or peel back the fabric to reveal the holding mechanism. If the chair is screwed in then you'll need a screwdriver, and if there's a nut or a bolt then you're going to need a socket wrench.
  • Hold the armrest up and make sure it doesn't move. Unscrew or unbolt the arm from the bucket seat. Pull the arm outwards once the hardware is removed.
  • Nov 13, 2012 | 2007 Dodge Grand Caravan SXT Minivan
    Top rack of dishwasher not getting clean
    The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
    Good luck.
    Aug 11, 2010 | Dishwashers
    Du1145xtpq top spray, and upper spray arm don't
    sounds like the chopper is plugged or broken. remove the lower spray arm by holding tab with a set of plyers and turn spray arm counter clockwise. then where the middle spray arm attaches at the back of tub remove screw. turn the housing on pump to the right side of the machine( its easier to pull top rack out a bit so that whole housing can move) it will turn a little bit to be released from top of pump. then take out the torx screws that hold the housing and filter on. in the sump there will be one or two more smaller torx screws remove those and remove coverings to the chopper. check to see if the mesh is plugged with food and other things. clean. also check to see if blade turn with the motor impeller. if not then the chopper needs to be replaced. good luck
    Dec 03, 2009 | Whirlpool Dishwashers
    I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
    your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
    there are only two styles of scroll saw blade, those with pins and straight blades without pins
    look carefully at your saw and you will be able to see which type holder you have
    Sep 15, 2009 | Saws
    How to install a read wiper blade on a FX45 2003... replacement blade requires that the blade be inverted for installation, but the fixture arm only raises about 3" ... not enough to swing the blade...
    Well, there is a clip in the middle of the factory blade that you press while sliding the blade to the left which will remove it. If you can't remove the blade, or if you absolutely must, you can completely remove the arm by popping off the cover at the base and loosening the nut that secures it to the motor shaft. You should be able to pop the cover off with a small flat screwdriver and the nut will more than likely be a 10 mm.
    May 18, 2009 | 2003 Infiniti FX45
    Need to replace driver side wiper do not know how to get it off
    I believe the blade is the same as my F-250, according to the manual. Pull the wiper away from the windshield, then push on either end of the blade, follow blade to pivot point at center, where blade pivots back and forth on wiper arm (wiper arm will not be moving as you do this). You need to push towards the windshield at this pivot point to push in on the wiper arm and out on the blade assembly to pop the round end of the wiper arm out of the hole in the blade assembly. Look at the new blade to see where this attaches. The new one should snap on to the arm when u squeeze the wiper arm to the blade. I prefer Exact Fit brand, as they seem to fit well. If u purchase at autozone, or advanced auto parts, they will install them for free.
    Mar 24, 2009 | 1994 Ford F150 Styleside Supercab
    Starfrit 93209 Rotato Express Electric Peeler Logo
    475 people viewed this question
    Top Starfrit Home Experts
    Donni Steen
    Tom Chichester
    Are you a Starfrit Home Expert? Answer questions, earn points and help others
