Question about Hoshizaki AM-50BAE Drain Pump Kit
Hoshizaki am-50bae pump won't stop
It makes ice fine but the pump never shuts off. Even when I move the switch it to the off position.
    Habit-Forming:
  • 76 Answers
Sounds like the water pump relay on the man circuit board is stuck in the closed position, try tapping the relays on the board with the handle of a screwdriver, sometimes this will jar the relay and cause it to unstick and work fine. Hope this helps. p.s. the relays look like black boxes on the board and there will be several of them. just tap them all.
Posted on Apr 26, 2014
2 Suggested Answers
kentguidry
  • 51 Answers
SOURCE: AM-50BAE won't stop making ice
There should be a copper bulb located in the ice bin. This is the probe for the thermostat. If you follow the copper line connected to this bulb it will bring you to the thermostat, and you may can adjust it. Please let me know if you need any more help.
Posted on Feb 20, 2009
I have a Hoshizaki AM-50BAE and it suddenly stopped making ice and all the ice melted away. Can it be fixed? What might be wrong?
the wiring diagram shows that if the bin thermostat goes bad, it will not send power to the control board and noting will run. look for that first, could be a simple fix.
Mar 29, 2015 | Hoshizaki Freezers
Hoshizaki am-25ae. We have inherited a AM-25AE with the lodge we bought and it works just fine. We do want to give it a very good clean inside and disinfect the whole water 'way' to ensure the ice won
Cleaning Instructions:
Water System
1) Dilute approximately 5 fl. oz. (148 ml) of recommended cleaner Hoshizaki " Scale Away" or "Lime-A-Way" ( Economics Laboratory, Inc) with 1 gal. (3.8 lit) of water.
2) Remove all ice from the Evaporator and the storage bin. Note: To remove cubes on the evaporator, remove the front panel ( Lower), move the control switch on the control box to the "OFF" position and move it back to the "ICE" position after 2 minutes. The harvest cycle starts and the cubes will be removed from the evaporator plate.
3) Move the control switch to the "OFF" position. Close the water supply line shut-off valve.
4) Remove the water tank to drain the water. Refit the water tank in its correct position.
5) Slowly pour the cleaning solution into the water tank.
6) Move the control switch to the "WASH" position.
7) After circulating the cleaner solution for about 30 minutes, move the control switch to the "OFF" position.
8) Remove the water tank to drain the cleaning solution. Refit the water tank in its correct position.
9) Open the shut-off-valve.
10) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
11) Move the control switch to the "OFF" position and immediately back to the "WASH" position to rinse water.
12) Repeat the above rinse procedure three more times to rinse thoroughly.
13) Dilute approximately 0.5 fl. oz. (14.8 ml) of 5.25% sodium hypochlorite (Chlorine bleach) with 1 gal. (3.8 lit) of water.
14) Move the control switch to the "OFF" position. Close the water supply line Shut-off-valve.
15) Remove the water tank to drain the water. Refit the water tank in its correct position.
16) Slowly pour the sanitizing solution into the water tank.
17) Move the control switch to the "WASH" position.
18) After circulating the sanitizing solution for about 15 minutes, move the control switch to the "OFF" position.
19) Remove the water tank to drain the sanitizing solution. Refit the water tank in its correct position.
20) Open the shut-off valve.
21) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
22) Move the control switch to the (OFF) position and immediately back to the "WASH" position to rinse water.
23) Repeat the above rinse procedure two more times to rinse thoroughly.
24) Move the control switch to the "ICE" position, and start the automatic ice making process. Refit the front panel (LOWER) in its correct position. abut do not forget to wash and sanitize the ice bin.
Sep 01, 2014 | Kitchen Appliances - Others
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Won' stop making ice
most likely the bin thermostat is not calibrated correctly or is not making contact with the ice. The unit should shut down within 5 to 10 seconds after ice makes contact and has not entered the freeze cycle.
Start there and if this does not resolve, let me know and we can get into more indepth things.
May 10, 2010 | Hoshizaki Commercial Freezer KM-500MAH
I have a Hoshizaki Model KM500MAE that keeps freezing up. What can I do to stop this problem
several things cause freeze ups.
If you have water filters on the water system, be sure they are not restricting the water flow. water flow pressure should not go below 20 psi.
The bin stat may not be shutting off the unit properly. It should shut off machine within 10 seconds of ice making contact.
Make sure the float switch is not dirty. Be careful when cleaning. Fragile
Make sure water pump runs the entire time it is in the freeze cycle.
Be sure the evaps are clean. Ice cubes will hang on if not clean.
Water solenoid has a screen where the water line screws on to it. Turn off water and check screen to be sure it is clean. This can restrict water flow.
Make sure water valve closes all the way. Turn machine off and see if water is still running. Valve may be leaking water thru.
Dip switches on the board, #1 and #2. Turn them both on and it will change the defrost time to 3 minutes. If both are off, they are set on 1 minute.
Hope this solves your problem. Let me know
Apr 07, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Nov 23, 2008 | Hoshizaki AM-50BAE Drain Pump Kit
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki AM-50BAE Drain Pump Kit Logo
103 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
