Question about Brookstone HDMI Pocket Projector
Pocket projector for iPhone 4 won't turn off
Help.... I can't get the blue projector light to go off. If I try to push slide to left to charge it stays on, if Inteybto put in in the middle to be off it stays on. The slide won't fo over to the right to turn on. Help.
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Feb 10, 2014 | Brookstone Pocket Projector for iPhone 4...
Iphone is not responding
Hold the top off button and one of the left hand side buttons push them in together untill phone reads slide to power off slide arrow and wait for phone to turn off wait about 1 minute then turn phone back on by pushing button on top of phone apple simble will come up resetting phone
Apr 05, 2013 | Apple iPhone4 4G iPhone 4
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
Have got blue vertical line on iphone 4 S home screen 3/4 inch from left side
I have an iphone 4 that i just fixed. it was working fine. i charged it and went to bed and when i woke up there was a blue line going vertically across the screen! help!
Jun 10, 2012 | Computers & Internet
Slide tray won t seat on projector
Try a couple of things:
1. Turn on the projector & cycle it in "Reverse" 3 or 4 times (without the tray). Do the levers that move the tray move correctly? If so, do you have another tray you can try? If another tray works correctly, follow Step #2.
2. The 140-Tray has to be in the "zero" position for the tray to seat on the projector. Check to make sure the Locking Ring (the ring is in the center of the tray & keeps the slides from coming out) is TIGHT on the top of the tray. Once checked, turn the tray upside-down. Refer to Page 8 in your owners' manual (if you don't have one, I've made an image of the page, below). You have to make sure the plate on the bottom of the tray is lined up at the notch at shown.jauburn_12.jpg
If this helps, please leave positive feedback for me @ FixYa.com. If you need more help, please re-post!!
Apr 13, 2011 | Kodak Carousel 5600 Slide Projector
Slides will not advance.buttons do not seem to work
1. Does the SELECT button work? If so, hold it & remove the tray (if one is present). Skip to step 3.
2. If the SELECT button doesn't work, remove the slide tray (if one is on the projector) using the emergency tray release in the center hub of the projector. 3. 3. Turn the projector on & try to cycle a few times in reverse. This is how you clear a slide change mechanism jam in the projector.
4. If that didn't work, then either you have a broken cycle circuit wire (usually an orange wire within the projector) or the release wire is trapped under the cycle pad. Refer to the following diagram for the correct "at-rest" position of these 2 contacts. (If you don't feel comfortable doing this, then contact a factory-trained repair dealer).
Good Luck !!
Feb 15, 2011 | Kodak Carousel 4400 Slide Projector
3gs Iphone will not charge
get a toothbrush and some methylated spirits, and clean the charging jack on the iphone, as it is most probably corroded. make sure the phone is off first. and just scrub it for a good minute.
good luck\\
nick
Jan 02, 2010 | Apple iPhone (16 GB) Smartphone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Kodak Slide Projector
sounds like the screen darking shutter is stuck up remove the lens and push it down with a screw driver sotf ly if it does not move go thru the open ing on the top of the unit and push down on the bar that operates the shutter
Sep 07, 2007 | Kodak ATS Ektagraphic Slide Projector
Brookstone HDMI Pocket Projector Logo
53 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Jerry Kramer
Jerry Kramer
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
