I have samsung shr-1041k when i do DDNS SETUP . DDNS SERVER NAME websamsung.net when i clik DDNS STATUS WILL SAY FAIL PLEASE HELP
3 Suggested Answers
SOURCE: Internet viewing of my home security system
Frank, if you have an external IP, you can open a port on your router and viewit that way. Works great for me. ANyone know how to view the system with Vista??
CAD...
Posted on Jul 13, 2008
  • 3 Answers
SOURCE: Samsung SHR-1041K. Cannot connect to DVR system "Unknown Error"
Samsung 1041k DVR - Camera Web Server Solutions. ' UNKNOWN ERROR' OR 'CANNOT CONNECT TO SERVER'
Holy Smokes! Can't anyone write a simple solution? The manual totally sucks. It tells you everything except the details that will complete the puzzle. The answers here, so far, are written by gearheads who can't write an easy sentence.
1. The user name is case-sensitive. So if you program the DVR with a user name it will only take capital letters by default ... so when entering the user name (USER ID) in the web setup ... It MUST BE CAPITAL LETTERS otherwise you will get an 'unknown error'. There is no mention of this important little fact anywhere....
2. Use Internet Explorer ONLY (becase of old Active X controls), not FireFox, Chrome, or Safari...etc...etc. IE9 doesn't like it either .. just goes white for the most part or flickers ..so IE8 seems to work best.
3: When programming the DVR Box using the MENU button and the 'NETWORK OPTION ...Use Port 6100 in the NET CLIENT PORT. In the WEB SERVER PORT use port 80. The difference is ... port 6100 is used for the basic connection of the network to the DVR device and camera hardware and software ..... and port 80 is for viewing through Internet Explorer. (Port forwarding in the router must direct those ports right back to the IP address of the DVR (whatever you set it to). TCP and UDP together work just fine... not necessarily one or the other . I tried it both ways .. they all work.
4. If you are lucky enough to finally get Internet Explorer to hit the DVR software via the correct IP address and port of the DVR.... then it will prompt you to install the Active X control software embedded in the DVR. You might hae to refresh the screen a couple of times for it to download and install. If indeed it does then you will get a blank box that will wait for you figure out you need to click on a little wrench to configure the DVR connection. Add the DVR (give it a name). Enter the IP address it was configured with .... and set the port to 6100. Remember to capitalize the User Id and put in the password and save .. Completely IGNORE the confusing little matrix boxes that are used for setting up multiple DVRs and cameras. Save the setup, it wil take you back to the blank Samsung box interface and wait till you figure out to hit the connect button in the center. If you did it all correctly then you should connect to the camera views..
4. If you are going to view the cameras from the home network .... then enter the IP address assigned to the DVR PRECEEDED by http:// . Believe it or not it seems to make a difference. If you are viewing from ..say .. your work.. put in the numerical address of your home IP address and if you have the port forwarding set up correctly you will be forwarded directly to the DVR camera software where you can sign in and see the screens.
I have set up many, many IP cameras and various DVRs and software packages professionally.. I must say that this DVR and software is not very intuitive and was very difficult to get past some of the issues. The included instructions were of little help. I hope this helps somebody else.
Gary
Posted on May 19, 2012
Gary
Jun 28, 2010 | Samsung 4 Channel Dvr
Samsung shr-1041k CCTV system with 4 cameras.
on most dvr 's the port is 80 for the web cam. you also need to set up the network settings and know the ip you are trying to hit and is it static or dynamic if dynamic it will change periodicly. for example if you set the network settings on the dvr to the rang of your local network it would be something like 192.168.1.10 so under your router you would open port 80 to ip 192.168.1.10. make sence. first thing i would do is make sure the network settings in the dvr are set to work within your network. unless you have an extra static ip you can put it right into the dvr. fi you need further help just ask.
Nov 03, 2009 | Samsung 4 Channel Dvr
What kind of "sensor" for SHR-1041K system?
if you bought the cameras that came with the system then you shouldnt need to worry about it because i didnt and my dvr works just fine.
Sep 19, 2009 | Samsung 4 Channel Dvr
DynDns update fails
I have given a ref. configuration for you. If you could provide me the debug results it would be great to help you.
set dns ddns
set dns ddns id 1 server-type dyndns clear-text
set dns ddns id 1 username USERNAME password PASSWORD
set dns ddns id 1 src-interface untrust host-name HOSTNAME.dyndns.org
set dns ddns enable
Then try exec dns ddns id 1
Oct 09, 2008 | Juniper Networks NetScreen-5GT Plus...
CAD...
Jun 20, 2008 | Samsung SSC DVR Digital Video Recorder...
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Can't access my computer onthe internet
  1. Make sure that your ISP is not blocking port 80. You can check that here. (Otherwise switch to another port like 8080 or 805)
  2. Have you setup your DDNS service on your router or ensured by other means that no-ip has your up-to-date external IP? (Make sure that your external IP matches the entry at no-ip.com!)
  3. Set your LAN server to a static IP address
  4. Make sure that port forwarding is enabled and pointing to your server.
    - That means: if you run a webserver on port 80, you have to set the external port to 80 and leave the internal blank, unless your internal server listens on a different port.
If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? Please provide details.
I think this might be interesting for some other people too. So please come back and leave a comment!
Feb 14, 2008 | Belkin (F5D6230-3) Wireless Router
Shr 2082
Question is pretty broad, what specific issues are you having connecting to the internet with your SHR-2162?
This is the link to the user manual for SHR-2162, http://www.samsungsecurity.com/files/product/SHR-2162(P)_User_eng.pdf . It might take a while to load because it is 190 pages. You would need to review Chapter 5-8 and 5-9 (for Network Setup on the SHR-2162 & Chapter 9 Smart Viewer.
You would need to install the Smart Viewer s/w on computer you would like to use and also you would need to setup the SHR-2162 for networking (ie are you using static or dynamic IP?). If you are still need troubleshooting, please ask specific networking questions so that I can help you.
Jan 14, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Update DDNS automatically
Dynamic DNS (Domain Name Service) is a method of keeping a domain name linked to a changing (dynamic) IP address. With most Cable and DSL connections, you are assigned a dynamic IP address and that address is used only for the duration of that specific connection. To properly configure the DDNS feature follow the steps below: Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click on the Tools tab and then click Misc. If you have the DI-614+ with firmware 2.30, click on Tools > Parental Control. Step 3 Enter the required information under Dynamic DNS: Server Address: Enter the IP Address or domain name of your DDNS server (IE members.dyndns.org). Host Name: Enter the Domain name that you registered with your DDNS service provider, (IE mydomain.dyndns.org). Username Password Step 4 Click Apply and then Continue to save your changes.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
