Question about EA Sports Madden NFL 2000 for Windows
Error enumerating process!!
Ea system information says that my cpu speed is -1338
  • Garey Neely
    Garey Neely Apr 02, 2014
    I'm running windows 7 64-bit system in 98 compatibility mode.CPU is an AMD Phenom II Dual Core
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
Tip
EZ System Repairs
Fixes stubborn errors, cleans out clutters, optimizes Internet speed, ensures personal security and maintains maximum computer performance in a more secure, stable, smart, automatic and reliable way. Users can tweak their system information, personalization, user accounts and user account controls, system performance, security settings, network tweaks, Internet Explorer, and more. Change icons on drives, folder and much more. The control manager let you changes all the users from a admin account and do it with ease. EZ System Repairs also has a hotkey system for fast repairs and tweaks. We added a Win Defender features to disable and enable with one click.
It also optimizes your system for games by temporarily suspending unnecessary processes, individually or all at once, to focus resources on gaming performance. It analyzes your system and suggests courses of action for all processes and services & cleaning RAM, and intensifying CPU performance.
Visit Total System Optimization
on Apr 01, 2016 | Microsoft Windows 7 Home Premium 64BIT...
System Idle Process uses 70 to 85% CPU in windows task manager
System Idle is unused CPU cycles, represented by the dark portion of the CPU graph/taskmanager icon. Hard to reconcile your saying CPU usage is 90% in Taskmanager when taskmanager is reporting 87% system idle at the same time. Enabling "show processes from all users" will unhide some running processes but it still shouldn't contradict that 87% unused CPU cycles. On the taskmanager Performance tab is show "one graph PER CPU" enabled?
What was changed in your system between the time these symptoms started and the last time it behaved normally? Did you try a System Restore to a point when it did behave normally?
Are your CPU core temperatures normal or high? Is CPU stepping reducing the core speeds, possibly because of power saving or overheating issues?
Jan 30, 2013 | ASUS Computers & Internet
Does a system with a high processing speed downloads files faster then the normal ones.how far will it effect the downloading speed for a system running 2 ghz processor and a system running 4ghz processor...
Not really. The limiting factor is the size of the "pipe" that gives you the content.
This is your internet connection.
Now once you start to process those files, that is where the CPU speed comes in.
Apr 25, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I can't save anything on my madden nfl 2003 on pc. I have windows 7 it always says -1.00mb. What do I need to fix the problem?
update the game using the update in the opening window. Should fix the memory problem, but might bring up "error enumerating processes" message. If so check tech. support. Look under system,look at cpu speed.
Apr 18, 2011 | EA Sports Madden NFL 2000 for Windows
The game slows and speed up back to normal speed
yes.
this is happening due to less memory availability
just download and install IOLO SYSTEM MECHANIC (you may download trial) run it and everything will be automatically corrected.
Jan 26, 2010 | EA Sports Cricket 07 for Windows
APPCRASH
nfs.exe "need for speed app." are you playing a ea game?update your graphics ,audio and keyboard drivers.rt, click on it go to properties check the compatibility mode. shutdown any unnecessary process in taskmanager,lots of people having problems.ea is working on a patch if you cracked the game yourself,it might be a bad crack..overwighting nfs.exe with original nfs,exe also helped a couple guys,good luck let me know if you discover any other fixes
Sep 07, 2009 | Acer Aspire 3935-6504 Notebook
UPGRADING TO 2 GHZ
1. Check user documentation for supported CPUs for your system.
2. If 2.0GHz CPU is supported on your system, you don't need any additional software.
3. I would upgrade the BIOS firmware first. It might have an additional CPU support.
4. Read information from you old CPU. Exemple: 1.4GHz/256/400. 1.4GHz is a speed of your CPU. 256 is a 256k cache, and 400 is 400MHz BUS speed. In general you can boost speed to 2.0GHz or more and cache to 512k, just keep your BUS speed to 400
5. Post your system model or your motherboard model. That information would help in determining the maximum speed of the CPU for your system.
Good lick!
Jun 08, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
MLTIPEL PROECESS EROOR
sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
May 14, 2008 | Dell Delta Electronics CPU Processor Fan...
CMOS Checksum error - Defaults loaded
When the CPU speed stored in BIOS and the actuall speed of CPU differs then this error comes.
To fix this you have to select the actuall speed of your attached CPU to the board. Just set the actuall speed and save the changes. It will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | EliteGroup P6STP-FL Motherboard
EA Sports Madden NFL 2000 for Windows Logo
41 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
param99
Level 1 Expert
Tony
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
