Question about Bushnell Sport 450 Yardage Pro Rangefinder 4X 20 Carry Case & Strap Charcoal 201916: Binoculars
The distance is always 20 yards off the correct distance
Yard to meters
1 yard = .9144 meters
I am guessing that is not the answer you want but more like how to change the reading from yards to meters on your compact 800 measuring unit
read the user manual to find the mode button and select distance or yards and change to meters
no manual , download one from the web site for the manufacturer
Jan 24, 2017 | Heating & Cooling
How many cubic yards would it take to fill in. 20' x 2' diameter
Hi Paula:
A mathematical logic question.
You need to get all of the measurements in the same units.
- A cubic yard is 1 yard x 1 yard x 1 yard
- equals 3 ft x 3 ft x 3 ft
- equals 27 cubic feet,
so once you have the volume of the pipe in cubic feet, you divide by 27 to get the volume in cubic yards.
- Volume of a cylinder (the pipe) is the cross sectional area X length.
- Area equals Pi x r squared.
- equals 22/7 x 1 x 1
equals 3.14#####
times length (20)
equals 62.857### cubic feet volume
divide by 27 cubic feet
equals 2.328### cubic yards.
- The answer is always the easy part.
- what is important is knowing exactly what the question is, and
- determing what calculations are needed to get the answer.
Wasn't that better than if I'd just said 2 1/3 cubic yards?
Cheers
Jan 05, 2016 | Office Equipment & Supplies
I compete in 3d archery so I bought a new rangefinder 2 days ago and it reads 19.2 yards at exactly 20 yards is there a way to adjust it to read properly?
Page 5 of the manual states: RANGING ACCURACY The ranging accuracy of the Scoutâ„¢1000 is plus or minus one yard / meter under most circumstances. The maximum range of the instrument depends on the reflectivity of the target. The maximum distance for most objects is 650 yards / 594 meters while for highly reflective objects the maximum is 1000 yards / 914 meters. Note: You will get both longer and shorter maximum distances depending on the reflective properties of the particular target and the environmental conditions at the time the distance of an object is being measured. The color, surface finish, size and shape of the target all affect reflectivity and range. The brighter the color, the longer the range. White is highly reflective, for example, and allows longer ranges than the color black, which is the least reflective color. A shiny finish provides more range than a dull one. A small target is more difficult to range than a larger target. The angle to the target also has an effect. Shooting to a target at a 90 degree angle (where the target surface is perpendicular to the flight path of the emitted energy pulses) provides good range while a steep angle on the other hand, provides limited ranging. In addition, lighting conditions (e.g. the amount of sunlight) will affect the ranging capabilities of the unit. The less light (e.g. overcast skies) the farther the unit's maximum range will be. Conversely, very sunny days will decrease the unit's maximum range.
The difference you are experiencing (20-19.2=.8 yards) is within the device ranging accuracy of 1 yard, and is in fact an error of only 4%. That is pretty accurate
In case you have lost your manual, you can download from here:
http://bushnell.com/getmedia/1761b4a2-f4d9-45f7-b1d3-1e400fead84a/REVISE-20-1932-20-19426LIM.pdf?ext=.pdf
Good luck with your device.
Jun 05, 2015 | Bushnell SCOUT 1000 Rangefinder
Situation--Having a discussion with son-in-law while sighting in my Winchester Model 94 30-30. I think it's sighted at 100 yards but shooting at 50 yard target. It is consistently high by about 5 to 6...
He is right the bullet at most will be 1/2 high at 50yards. Zero at 100 if sighted correctly. The bullet is flat to about 100 yards and will drop significantly for the next 300 yards. At 400yards your drop is almost 7-8 inches and at longer than that the bullet loses most if its effective stopping power for hunting and the drop is really significant. Not worth the effort......
Nov 03, 2013 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
A land developer wants to find the distance across a small lake in the middle of his proposed development. The bearing from A to B is N14^0W . The developer leaves point A and travels 53 yards...
f.
You'll probably have finished your homework by now if you worked on it instead of typing it in to FixYa. Besides, how much do you trust me?
Sep 25, 2013 | Optics
Diference between yd and cubic yd.
A yard is 1 dimensional so just a straight line.
A cubic yard is 3 dimensional so imagine a box with all sides being 1 yard long, the volume of this box is a cubic yard.
May 04, 2011 | Office Equipment & Supplies
I purchased a new LR 559 Callaway golf rangefinder from a QVC auction. The problem with it is it isnt even close to accurate. I have a measured archery range back to 65 yards and the rangefinder is way off...
its a piece of ****, that happens when you arder through qvc. When you arder electronic devices for weights or measurements, first you must know exactly what you are looking at, make, model, and series,,, then read all of the reviews you can,, then go to a pro store-- (like our shop we are a pro archery shop) we refuse to work on peoples bows they bring in that they bought online, because half the time they recieved something that they did not order, they dont look like they did in the picture that the seller posted... always read reviews and ask the professionals.... I would return the item even if it was an auction, if you cant return it then ebay it-- but be honest when you post descriptions of the item, and the problems that you may be experiencing, trust me the buyers will appreciate it...
Sep 11, 2010 | Nikon Unisex LR550 Rangefinder
I'm using a red dot scope on a mossburg turkey gun with a choke. I'm using the 3'' heavy tungston loads for longer distance shots. What distance should i zero in the scope at? 20 yards? 30 yards? 40 yards?...
I set my sights for 30 yards.40 yards is a long shot because you always aim for the head when hunting turkeys.Good luck with the Mossberg.I traded mine for a Remington.Still got a Mossy for a "loaner" or a backup gun for a client.The 3.5 magnums are simply too punishing to the shooter.
Mar 08, 2009 | Optics
Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Sport 450 Yardage Pro Rangefinder 4X 20 Carry Case & Strap Charcoal 201916: Binoculars Logo
75 people viewed this question
Top Bushnell Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bushnell Photography Expert? Answer questions, earn points and help others
