Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony KDL40BX420. Worked great for 3 years. Turned it on the other day and the LCD statretd to come on then went completely dark, no sound either. Any suggestions or has the LCD died.
Worked great 3 years. turned it on the other day and the LCD started to come like normal then went dark. Do not have sound either. LED blinks 6 times and repeats. Has the LCD died? Or it is possibly the main power board? Has been plugged into a surge protector all along. It still functions, no known spikes.
  • ejohnson3 Apr 03, 2014
    Several people have stated the thermal fuse may have blown. I understand how to bypass, but what can I expect IF the LCD lamp has died? Any risks? Is there a way to test the LCD in this unit, or is bypassing the thermal fuse the only way. This TV was in a garage its entire life. No less than 45 degrees (heated) and no more than about 95 degrees in the summer. Would the heating/cooling cycles have any impact?
  •  Mike M
    Mike M Apr 03, 2014
    Sitting in a garage, dust and grime settling on the interior boards and connectors, then power gets applied....Three years is a long time. I have no advice about monkeying around with fuses, thermocouples etc.
  • Sony Master
  • 3,320 Answers
I searched the manual but no reference to led codes.
I would contact Sony support. Sony is a great company and will stand by their products.
Posted on Mar 31, 2014
dsacco86
  • 1077 Answers
SOURCE: my sony kdl40z4100 will not turn on. It worked
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
TVtechmaniac
  • 140 Answers
SOURCE: PICTURE WENT BLANK TV TURNED OFF
Replace the thermal fuse part# 1-910-006-44 You can verify this by jumping the connector where the fuse connects and the lamp will come on.
Posted on Aug 21, 2007
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
  • 1779 Answers
SOURCE: My LCD Sony HD tv turns off after few seconds.
You need the Inverter Board.
Posted on Sep 14, 2009
  • 608 Answers
SOURCE: Sony Bravia model #KDL52WL130 worked
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Is it a problem of the inverter board ?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 12, 2016 | Sony 40 KDL40BX420 LCD TV
Samsung 21.5 LCD monitor suddenly turned dark. Can this be fixed or should I just trash it?
Your monitor has symptoms of power supply failure. The age of the monitor and the cost of repair will influence your decision whether to repair it or dump it
Feb 25, 2013 | Computers & Internet
Tv freezes in standby mode
If it is still under warranty, TAKE IT BACK
Jul 28, 2012 | Sony 40 KDL40BX420 LCD TV
Sony Bravia model #KDL52WL130 worked fine for first year then picture went very dark for the 1st 30 minutes it was on but eventually cleared up. Now it takes longer and screen is completely blank. Sound...
Solutions?
Hope this helps
Dec 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Dark area on Sony LCD screen model KDL-46XBR4
This model of SONY TV uses a Samsung display panel, the problem you have is the panel went bad.
SONY was offering an extended warranty to change the panel free, please call SONY to check it out that if they still offer the free replacement.
Sep 26, 2017 | Sony KDL-46XBR4 46 in. LCD Television
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
LCD Screen goes dark
Get a replcaement tv unless doing a reset fixes the issue.
Jan 20, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
No image in the viewfinder or LCD
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free.
May 29, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
