Question about Pitco Frialator SG18S Deep Fryer
How do i clean fire tubes pitco frialator
How do i clean fire tubes pitco fryalator
bigg t
  • 640 Answers
SOURCE: converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Posted on Dec 12, 2007
burzerko
  • 254 Answers
SOURCE: Pitco Fryalator
This is caused by a failing pilot safty bypass inside the gas valve itself. You will need to replace the gas valve.
Posted on Aug 28, 2008
SOURCE: Pitco Frialator Model 14S
Excellent reason to use Dormont flex lines.
If water gets to your combination valve (the thing with the on-off knob,) it should be replaced. Can you hear gas hissing? If there is gas at the orifice, it should light. check to see that all of the air is purged. Can you smell gas?
Posted on Sep 30, 2008
SOURCE: want to convert pitco frialator model 14 from gas to propane
I agree - What everyone fails to tell you about conversion from Natural Gas to Propane -
1 - Take your time -
2 - The parts you get may be to many
3 - If you are going to use the unitl out-side - Wind is not your friend -
4 - While 20lb tanks will work - 60lb tanks are the best
I have found that only 70% of the gas in a 20lb tank will be used - the Amount of preasure / volumne decreases as the tank gets empty - a gas grill will empty a tank - a Deep Fryer (I have a Pitco 14 and 35c) will not - therefore, 60lb tanks
5 - Also, a 3/8 hose and connections will work, but 1/2 hose and connection work better - especially with a 60lb tank
6 - Find a good welder supply store to work with to get the hoses and adapters - Stay away from Lowes, Home Depot and other Box Stores - They are ok for most things, but not this project - Pay the extra money for the right stuff.
1 - Have 3/8, 7/16 and 1/2 wrenches - Open and Box style
2 - A very good philips and slotted screw-driver
3 - Remove the Front Door and Front Panel
4 - Remove the Burners - Be careful - they are heavy and if dropped, they do crack
5 - The orfices for the burners are simple to change
6 - The Gas Regulator on the Control valve is simple - not easy to get to, but simpe to change - and make sure it is tight, (so it does not leak) but not to tight - it can craxk
7 - The silver thimbel - it is a atomizier for the pilot - is also easy to replace, but hard to get to - don't bend the gas tube to much and be carefull removing the old one - it is jamed into the pilot
8 - Wind - IS NOT YOUR FRIEND - If outside, you need to cover the left, back and right side from wind - it will push the gas out of the burner (at the orfice) and into the cabinet and it will "POP" with gas - the orfices will have little flames on them - very yellow and very bad -
Posted on Jul 10, 2009
SOURCE: What are most common problems found with pitco
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
Posted on Jul 04, 2011
Soot coming out of flu
Hi there.
Soot coming out of the flue indicates poor flame quality and probably carbon or soot build up on fire tubes.
Have a technician check the gas pressure and the fire tubes for verification and cleaning if needed.
Regards.
Sep 23, 2013 | Pitco Frialator 35CS Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
My fryer burns with alot of black soot
you need to clean the burners and the fire tubes, remove all carbon deposits.running the unit on low gas pressure results in carbon build up on burners and fire tubes.
Mar 11, 2011 | Pitco Frialator Kitchen Appliances -...
Soot coming out of flue (chimney) on the back of the fryer.
you need to clean the burners and fire tubes, remove all carbon deposit and make sure that the unit receives sufficient gas pressure as labeled on the nameplate.
Mar 07, 2011 | Pitco Frialator 35C Deep Fryer
What are most common problems found with pitco frialator fryers?
Feb 09, 2011 | Pitco Frialator SG14 Deep Fryer
Flames coming out of the exhaust
Clean burners and orifices clean tubes heat tubes and also check the exit to the stack on the deep fat fryer. check pressure. fire off
Dec 18, 2010 | Pitco Frialator PIT40SN Deep Fryer
Fryer shuts down including the pilot light once it reaches temp
Hi there, try here and check your state, and pick a company close to you, they will either have the part you need, or can get it relatively quickly.
http://www.pitco.com/serv.asp
Hope that helps, and thank you.
Jan 19, 2009 | Pitco Frialator Kitchen Appliances -...
Pitco Fryalator
Aug 11, 2008 | Pitco Frialator SG14 Deep Fryer
Burner Welds
You have your burners misaligned with the tubes. Re-align the burners and the welds will hold up fine.
SuperTech1
Mar 26, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG18S Deep Fryer Logo
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
