Question about Frigidaire FEF352 Electric Kitchen Range
Getting F10 on oven
Wont turn on and in window F10 displays
  • Official Brand Answer
  • 4,342 Answers
Good Morning Kathy, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code F10, it typically indicates that your Frigidaire range (FEF352) has detected an issue with the runaway temperature (overheating). Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (Electronic Oven Control) will need replacing. Hopes this help!
Posted on Apr 01, 2014
What does it mean when F-10 shows on oven display frigidaire range
Good Afternoon friend, thanks for your post!
Based off the information you have provided your range is displaying an "F10" error code. "F10" typically means that your wall oven has detected an issue with the runaway temperature (overheating).
Sometimes resetting your appliance can correct this issue but in the case that it does not and you still receive that error code I would recommend having a professional come out to properly diagnose and repair. At that time you could be having an issue within RTD (Resistance Temperature Detector) sensor probe or the EOC (Electronic Oven Control) having a professional come out would reduce the cost of unnecessary parts. I hope this information is helpful. -Matt
Oct 18, 2014 | Frigidaire Kitchen Ranges
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
F10 error message oven 790.9612
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Kenmore Ovens
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is sending a code on the digital display F10 it does turn on and heat up but then after a few minutes i get the F10 code the top of the stove(burners) are operating fine
this is usually the code for a runaway temperature. it means the control thinks the oven is too hot.
you might have a sensor that is out of range and it can be replaced easily.
try this and it should fix your troubles
Jan 09, 2010 | Ovens
Oven F10 Problem
PJC,
From the Frigidaire service manual:
"F10: Runaway Temperature.
SUGGESTED CORRECTIVE ACTION
1. (F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive."
-hopefully it's just a bad temperature sensor!
www.fixyourboard.com
Jul 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
What does F10 display on my stove mean? Frigidaire Model PGF355DS
my frigidaire oven keeps flashing f10 and turning off
Apr 02, 2009 | Ovens
Laptop is not able to open windows. mine is HP pavilion dv4000 p/n is EP360 UA#ABA- dv4320us
If the laptop boots up press F10 when F10 is displayed on the lower left of display and ensure that the hard drive is selected for first boot. If Windows still doesn,t boot then put the system restore cd/Windows cd in and boot from that.  If the display has nothing make sure that the brightness is not turned down or connect an external monitor. At this point repost to get more info.
Oct 25, 2008 | HP Computers & Internet
Frigidaire FEF352 Electric Kitchen Range Logo
275 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
