Question about EnGenius EOC-2611 - Wireless Access Point 802.11b/g 600 mW Dual-POL E
Slower wireless speeds
I have two engenious eoc2611 one as a access point one as a bridge. Ive used them for 2 years and no problem. I recently switch from verizon fios to comcast and my download speeds wirelessly are cut in half. But my hard wired speeds are up. Is there some kind of setting i have to change, thanks
    Scholar:
  • 49 Answers
Sorry to see you leave FiOS.
Without knowing how your EOC-2611s connect to your network, I can only speculate. But...assuming your 2611 plugs into the Comcast router... Check the Ethernet port status. It should be 100Mbps Full (Duplex). If it auto-negotiated to half duplex, that would explain your throughput issues.
Posted on Jun 12, 2014
Engenius eoc3220-w outdoor access bridge set-up
The POE should have a balun/power supply. You plug a data cable with RJ45 connectors into the power injector and that will go to the access point. You will need either a cable running out to that or you will need the antenna (send and receive side) to get the signal there wirelessly. If you use this option the you will get up to two miles that you can shoot the signal. You will need a router to send the signal. If you give me a complete list of what you have from Engenious I can map this out for you.
Apr 20, 2014 | Computers & Internet
Engenious eoc2611 slow speeds when i changed internet providers
No setting would have any effect on that. If you are downloading the same file from the same site on both wireless and wired, and nothing changed other than your ISP, then there is not much that can be said other than wireless is always questionable, anything in the environment including your neighbors moving furniture, or adding or changing their own wireless network can effect your wireless network. The connection to the wireless access point would not effect the speed of the wireless network. That being said if the tests that you are doing involve different files or downloading from different sites, keep in mind that Comcast limits the speed of connections to sites if they feel it is using too much bandwidth and the owner of the site does not pay fees to Comcast.
Mar 30, 2014 | EnGenius EOC-2611 - Wireless Access Point...
Power light is on but other light is off
Hi, maybe it´s necessary to restart router, in the following link you can download manual and find the process to do it: WCR GN AirStation Technology 150Mbps Router Access Point and Bridge
Nov 11, 2017 | Buffalo Technology Buffalo Airstation...
Can I use one wireless router to connect to my primary wireless router?
You wouldn't use a wireless router for the second device -- you would use a wireless bridge device. Most Wireless Access Points can be configured to be wireless bridge devices or you may be able to find a dedicated wireless bridge. Unfortunately, these devices usually have just one Ethernet port. That will mean that you'll need to buy an Ethernet switch in addition to the device that you're going to be using as a wireless bridge. This will add to your cost and make it so there is no real cost savings by using the Wireless Bridge + Ethernet switch combination.
If you can find a wireless bridge unit that has more than one Ethernet port, then you may be in business.
Using a second wireless router will not work unless the device has the ability to be configured to be a wireless bridge. Such routers are usually more expensive than your typical router, but you might get lucky and find one at a good price.
Good Luck
Feb 09, 2012 | Linksys Computers & Internet
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Good Signal, Good Speed, Slow Internet?
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
EnGenius EOC-2611 - Wireless Access Point 802.11b/g 600 mW Dual-POL E Logo
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
