Question about Pitco Frialator Kitchen Appliances - Others
How to clean flue pitco frialator
How do i Clean the Flue ?
bigg t
  • 640 Answers
SOURCE: converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Posted on Dec 12, 2007
  • 5 Answers
SOURCE: pitco frialator
Is it doing more than lighting the pilot light? Or is the only action is the pilot light coming on, then off?
I would need to know more spacifically which model you had. Here is a list of manuals on the manufacturers web site so you can see for yourself.
http://www.pitco.com/doc_lib.htm
If I were to look at your unit, I would first look for, and see if there is a sensor (sometimes appears to resemble a piece of coat hanger sticking through some ceramic) that the flames will heat. The warming from the flames generates electricity. The electricity keeps the gas flowing. It is a safety device to keep your home/business from exploding from a build-up of unburnt gas.
Make sure the sensor is being hit by the flame. If it is, and the flame still goes out, then it just might be bad. I would imagine it would run about $20 for a replacement part.
if it works, great! If not, then you are only out $20.
Posted on Apr 27, 2008
SOURCE: want to convert pitco frialator model 14 from gas to propane
I agree - What everyone fails to tell you about conversion from Natural Gas to Propane -
1 - Take your time -
2 - The parts you get may be to many
3 - If you are going to use the unitl out-side - Wind is not your friend -
4 - While 20lb tanks will work - 60lb tanks are the best
I have found that only 70% of the gas in a 20lb tank will be used - the Amount of preasure / volumne decreases as the tank gets empty - a gas grill will empty a tank - a Deep Fryer (I have a Pitco 14 and 35c) will not - therefore, 60lb tanks
5 - Also, a 3/8 hose and connections will work, but 1/2 hose and connection work better - especially with a 60lb tank
6 - Find a good welder supply store to work with to get the hoses and adapters - Stay away from Lowes, Home Depot and other Box Stores - They are ok for most things, but not this project - Pay the extra money for the right stuff.
1 - Have 3/8, 7/16 and 1/2 wrenches - Open and Box style
2 - A very good philips and slotted screw-driver
3 - Remove the Front Door and Front Panel
4 - Remove the Burners - Be careful - they are heavy and if dropped, they do crack
5 - The orfices for the burners are simple to change
6 - The Gas Regulator on the Control valve is simple - not easy to get to, but simpe to change - and make sure it is tight, (so it does not leak) but not to tight - it can craxk
7 - The silver thimbel - it is a atomizier for the pilot - is also easy to replace, but hard to get to - don't bend the gas tube to much and be carefull removing the old one - it is jamed into the pilot
8 - Wind - IS NOT YOUR FRIEND - If outside, you need to cover the left, back and right side from wind - it will push the gas out of the burner (at the orfice) and into the cabinet and it will "POP" with gas - the orfices will have little flames on them - very yellow and very bad -
Posted on Jul 10, 2009
dmftrucker
  • 1922 Answers
SOURCE: How do I test the Pitco Frialator 35CS high limit switch
remove connections from hi-limit switch, and put an ohm-meter across connections then heat it with a match or heat source of that temp range,heat the face and watch your meter it will show open when hi limit reaches cutoff limit/if you need exact cutout temp,you will need to have one of those digital read-out temp gun
Posted on Jul 27, 2009
  • 77 Answers
SOURCE: black smoke coming out of flue and two burners
First.. the burner tubes need to be cleanes...sounds like a few have soot build up. Messy job...do outside with a hose. Check the burner orifice size to make sure they are all the same.
Tom
Posted on Aug 17, 2010
Flames coming out of the flue
There is most likely oil/oil residue in the chimney.
Apr 20, 2014 | Pitco Frialator 35CS Deep Fryer
Soot coming out of flu
Hi there.
Soot coming out of the flue indicates poor flame quality and probably carbon or soot build up on fire tubes.
Have a technician check the gas pressure and the fire tubes for verification and cleaning if needed.
Regards.
Sep 23, 2013 | Pitco Frialator 35CS Deep Fryer
When i set the thermostat to desired setting flames shoot to the front of the fryer
Hi Dan.
Check if the fire tubes are clean, exhust system must be operating well during fryer operation. There should be no fresh air directed at the flue stack of the fryer, only exhaust.
Regards.
Oct 26, 2011 | Pitco Frialator SG14 Deep Fryer
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
FIRE IN FLUE
There may be soot/ carbon build up inside the fire tubes that's why flame crawl all the way to flue. Also check if your fryer receives the right gas pressure and type as rated on the nameplate.
May 27, 2011 | Pitco Frialator SG14 Deep Fryer
FLAMES ARE COMING OUT THE BACK OF MY FRYER,WHAT WOULD BE THE PROBLEM
There may be an excessive carbon deposits inside he heat tubes of your fryer, you have to clean/ remove these carbon to eliminate flames coming out of the back of your fryer (flue riser).Carbon build up on heat tubes are due to low gas pressure and volume; incorrect air and gas mixture.
Apr 17, 2011 | Pitco Frialator SG18S Deep Fryer
Should there be soot in the flue deflector? How often should this be cleaned out and what is the best way to clean this out?
Soot is formed when the fuel combustion is incomplete. Incomplete combustion may occur if the fuel is low, air and fuel mixture is not correct, wrong size of burner orifice with respect to the fuel used ( propane or natural gas).
Soot can be removed by wiping it off with a nylon scrubbing pad dipped in grease cutting solution. Check also the fire tubes for soot or carbon build up.
Apr 10, 2011 | Pitco Frialator 35CS Deep Fryer
Soot coming out of flue (chimney) on the back of the fryer.
you need to clean the burners and fire tubes, remove all carbon deposit and make sure that the unit receives sufficient gas pressure as labeled on the nameplate.
Mar 07, 2011 | Pitco Frialator 35C Deep Fryer
Is there an easy way to get access to the rear vent to clean away soot and buildup?
You have to dismantle the back panel to have access in cleaning the flue. Soot formation or carbon build up on fryers are due to low operating gas pressure. When the fryer receives lower than the nameplate rating gas pressure, the flame on burners will be of poor quality (yellow flame) which will in turn produce soot/ carbon.
Jan 30, 2011 | Pitco Frialator 35C Deep Fryer
Kitchen Appliances - Others Logo
60 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
