Question about Nikon Callaway LR800 Rangefinder
I have to aim right of my target to get a proper reading. Is there a way to adjust this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
No matter what type of rangefinder you have....this one needs service. Aim right....Hit straight....!!!
This is funny no matter what type of player you are!!!!
MTG
Posted on Jun 25, 2009
Sighting my rifle scope
Mount scope on rifle with the eye relief you are happy with
set up a target at 10 yards and fire 5 rounds of until you are grouping tightly ( no fliers ) you may want to use quite a few targets once you are happy with the grouping remove the adjustment covers on the scope
the top one is for moving the point of impact up or down
the side one is for left or right
depending on the point of impact you need to move it up or down to meet the cross hare once you get the point of impact on the same hight line as the aim point you can move the side adjuster to move the poi to meet the aim point
then move the target out to 20 yards and repeat the above again
then move the target out to a distance that you can put 90% of your shots inside 40mm or better and that is your max range for live animals
Dec 15, 2017 | Remington Optics
Error 22-23-26
Precor Error Code 23
Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Precor Error Code 22
Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  4. Damaged speed sensor target.
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Precor Error Code 22 Precor Error Code 23 Precor Error Code 26
May 13, 2014 | Precor C964 Treadmill
9.31 precor error 26 and loud noise
Model: All Models
Recommended Action:
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
Dec 16, 2013 | Exercise & Fitness
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
What does Err26 mean?
Model: All Models
Recommended Action:
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
Nikon Callaway LR800 Rangefinder Logo
212 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
