Question about BYTECC Computers & Internet
Problems installing an IDE disk drive in a Bytecc ME-350V4
I just bought a Bytecc ME-350V4 HDD enclosure in an attempt to use use (and recover data from) an IDE disk drive. When I openned the box I discovered there were no instructions and no manual. When I removed two screws and openned the case I found a ribbon cable (the IDE data cable, I assume) and a 4 wire cable (which I believe is the IDE power supply cable). Both of these cables were sitting loose inside the case. SATA cables were connected to the circuit board, but I am not trying to use a SATA drive. I can not find any obvious location to attach the (assumed) IDE power supply cable and I am not certain which way the ribbon cable should be installed.
3 Suggested Answers
Jim1969pa3
  • 152 Answers
SOURCE: Model md-aen350com not found
Sometimes the drives pull too much current to start. I understand that it worked in the other caes, but the electronics in this case may be pulling more.
Usually they come with a two-headed USB connector. Try putting the single end in the drive and use two USB ports on the other end. This doubles the current available to the drive.
Posted on Dec 22, 2009
SOURCE: Bytecc ME 350V4 external drive
Two philips screws on the back.
Posted on Feb 10, 2011
Installing IDE drive in Bytecc ME-350V4 (no manual supplied)
It sounds from your description you change out some hardware and left the wire behind. IDE is consider to be old technology replaced by SATA. Unless it broken don't play with the wire, you could either leave the wire handing loose or just remove the ide ribbon wire, either way it won't hurt the computer.
Mar 30, 2014 | Computers & Internet
Need manual for me-350v4
I NEED ONE AS WELL...This is the first computer item I have purchased without a manual. I can not even find a download for the manual. HELP!!!!!!!!!!!!!!!!!!!!!.
Feb 07, 2013 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
I am a complete novice, can you help me please? I have purchased a 3.5 SATA/IDE back up enclosure to transfer files from old to new desktop. I have removed frame holding old harddrive into tower but cannot...
You want to remove the hard disk from old computer, connect it to the enclosure, and connect it externally to the new computer, right?
Now you have a problem connecting hard disk to the enclosure.
Usually there are no SATA/IDE enclosures. They are either IDE or SATA.
If the data connector in the hard disk (HDD) is rectangular with around 40 pins inside, it is an IDE HDD. Else if it has L shaped horizontal connector, it is a SATA HDD.
I suggest you to take the hard disk to the store and ask for a matching enclosure. If you bought the wrong one, they might replace it with the correct one.
If you feel you want to do it yourself, let us know. However an IDE HDD cannot be connected to a SATA enclosure and vise versa.
I sincerely hope you will get to copy the required files to your new computer. However before copying, it is better to install a reliable virus guard.
Sep 14, 2011 | Computers & Internet
How do i put my hard drive inside? me
Open the external case, by removing some screws, and sliding the cover away from the insides.
Connect your disk-drive to the "power" and "data" connections, and secure the disk-drive with the mounting screws. Close the case.
Jul 25, 2011 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
My external hdd from bytec is not recognized by my computer. What shall I do?
Try to use direct connection to your computer. Using IDE cable.
If your comp can detect, means your external casing problem.
If not detect, your hard disk problem
Jul 09, 2010 | BYTECC ME-740 Aluminum 3.5" Hard Drive...
IDE hard drive in Bytecc ME-535U2 enclosure not recognized by OS
smc4
There is a couple of things that could be going on. The first thing to check is that the drive did not get bumped off its drive letter by another device. If that is the case you just the to assign it a new one. The link below will help you do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
The other issue is the drive may have gotten disconnected improperly. I had the same problem with one of my drive on my XP system as well. It partly has something to do with the USB controller to my understanding. Alot of times if you plug it into another computer it will detect it and ask to run a scan to repair the drive. After this you should be able to access the drive on your XP system again. Note I have the best resolutes when I plugged the drive into my Vista system. So I would recommend trying to plug it into a Windows Vista or 7 computer to attempt the repair.
Let me know if you have any more problems or questions.
Issken
Feb 23, 2010 | BYTECC ME-535U2-BK Aluminum 5.25'/3.5'...
How to use 2.5" SATA external hard drive
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory disk / hdd to the computer , run the program.
On the program , select the dig deep option for accidentally deleted files or dig deeper for a formatted drive. Then select the disk you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the data was lost. Save the files to a location on the computer hard drive and not back to the disk it is recovering from as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Apr 01, 2009 | BYTECC 3.5in SATA + USB 2.0 External Hard...
I turned of my eMac without turning of the 3.5 HDD external enclosure and now the icon does not pop up on my desk top? How do I get the icon back
Boot eMac
Unplug the DATA cable for the external HDD where it enters the computer.
recycle power to external HDD
plug the data cable for the external HDD back into the eMac.
Icon should appear after a small delay.
IF NOT -- Reboot eMac.
Mar 10, 2009 | BYTECC Aluminium 3.5" HDD Smart Drive...
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Computers & Internet Logo
129 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
indiana650
indiana650
Level 1 Expert
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
